Thread: a new noise after installing an expansion tank
    DIY Junior Member jlp's Avatar
    Feb 2013
    missouri
    Default a new noise after installing an expansion tank
    I had a hot water tank blow it seam somewhere it was leaking or should I say poring water out of the outer jacket. It was covered under warranty. but i chose to install an expansion tank on the cold water inlet of said water heater, now I have a rumbling noise when I run water and the pressure fluctuates. How can I stop the madness?
    Moderator valveman's Avatar
    Mar 2006
    Let some air out of the expansion tank.
    Feb 2013
    missouri
    that did not help
    Mar 2006
    OK, then you need to check the air pressure in the tank. Turn the water off to the house and open a faucet to drian house. Then check tank air pressure with a car tire gauge. You need about 30% less air pressure than the lowest water pressure you see in the house.
  1. Whining/noise returns after expansion tank install on cold water line - help!!
    By nards01 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-11-2012, 07:01 PM
  2. New Expansion Tank noise after somebody takes a shower or lots of hot water use...
    By DoofusOfTheDay in forum Water Heater Forum, Tanks
    Last Post: 10-18-2011, 12:19 PM
  3. Replies: 15
    Last Post: 06-06-2011, 04:55 AM
  4. installing an expansion tank
    By kskier in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-22-2009, 07:39 AM
  5. installing expansion tank
    By lewe in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-06-2005, 08:44 AM
