Results 1 to 4 of 4
Thread: Tub vent
    DIY Member mar3232's Avatar
    Oct 2011
    Indiana
    Default Tub vent
    My toilet and bathroom sink are right next to each other and both are vented with a 2" pipe, with the separate run for the sink that connects about 4 feet up as I've seen in the diagrams for venting.
    I can also run a vent for the bathtub but it will be a pain as it's across the room (about 5 ft).
    Is it really necessary to have a vent for the tub or does the overflow drain let it drain well?
    THANKS.
    DIY Senior Member asktom's Avatar
    Nov 2009
    Victor, MT
    It needs a vent after the trap. The overflow won't protect the trap seal.
    The overflow is NOT a vent, and HOW the tub connects to the main line determines whether it needs a separate vent or not.
    Oct 2011
    Indiana
    Yes the vent will be about 5 feet from the tub after the p trap. I'm putting the vent right between the toilet and sink in the wall (2" pipe).
    Toilet > vent < Sink The sink and tub will wye into the main 3" drain coming out of the toilet and I will also run a 2" pipe from the sink upwards into the vent.
    Like that deep space Hubble photo -- I have it framed in my home.
  1. Power vent, direct vent or natural draft chimney
    By Islander in forum Boiler Forum
    Last Post: 08-15-2012, 11:51 AM
  2. In-wall vent for waterfall drain?? Air Admittance Valve or cheater vent
    By conroyt in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-31-2012, 07:47 PM
  3. Can I vent two sinks with a single foot vent upstream? thanks
    By k52 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-14-2012, 05:05 AM
  4. Convert dryer vent to range hood vent?
    By petergunn in forum HVAC Heating & Cooling
    Last Post: 11-10-2009, 03:42 AM
  5. Can I vent New bathroom vent into dryer vent line?
    By cwolters in forum Shower & bathtub Forum & Blog
    Last Post: 04-25-2005, 04:03 PM
