Results 1 to 4 of 4
Thread: Is a vapor lock possible?
    DIY Junior Member Nancylf's Avatar
    Feb 2013
    NH
    Default Is a vapor lock possible?
    Our toilet on the second floor is possessed ! Sometimes it flushes just fine and sometime it won't at all unless aggressively plunged. It has been getting progressively worse over the 4 years we've been using it. We can flush it with absolutely nothing but water in it and get the same result. THere is no pattern to when it will flush and when it won't.
    Here are the details:
    it has a 4" drain and the toilet itself is a regular American Standard 1.6gpf. My husband has pulled the toilet and found nothing in the toilet trap or the drain pipe, pulled the vent stack at mid point in our attic and looked up to the sky and as far down as possible and found nothing and opened the clean out in the basement while I've flushed and watched water rush by. The septic tank was pumped in November so we know that's not full.We've tried pouring water in the tank and directly in the bowl : same inconsistent result. We've also cleaned out the holes under the rim to make sure no mineral deposits are there.
    We are in the process of building this house (a 10 year process!) and the first floor toilet is not yet installed. There is just a rag stuffed in the 4" pipe to keep gases from coming in.
    The two toilets are in a straight line (stacked bathrooms) and share the same drain and vent system. We're stumped.
    Is it possible that somehow when we flush on the second floor we are gradually sucking in air through this 1st floor rag filled pipe until after a few flushes we are creating a vapor lock (or something similar) in the 2nd floor that is only "broken" with plunging? Any ideas would be greatly appreciated!
    The answer to that question is easy, NO!, But, without being there it is impossible to diagnose it just based on what you have written. If you did the plumbing yourself, did you put a "P" trap under the toilet?
    Feb 2013
    NH
    No we did not plumb it with a p trap under the toilet. The toilet itself seems to have a p trap like configuration as part of it's whole trap/bowl exit system.
    The toilet has an integral "S" trap, but amateurs sometime think it needs a "P" trap under it like a sink would. Doing THAT can cause flushing problems such as you describe.
  1. storm door lock set
    By Master Brian in forum Remodel Forum & Blog
    Last Post: 09-23-2009, 10:27 AM
  2. Oil cap lock?
    By Andrew21 in forum HVAC Heating & Cooling
    Last Post: 09-24-2008, 11:47 AM
  3. Air lock
    By jadnashua in forum HVAC Heating & Cooling
    Last Post: 12-04-2007, 03:44 PM
  4. Hot Water Heater Lock?
    By pcleiter in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-21-2006, 05:26 PM
  5. outdoor faucet lock
    By stoeckle in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-24-2005, 11:56 AM
