Results 1 to 4 of 4
Thread: Cracked gas regulator on new stove?
    DIY Junior Member TedSF's Avatar
    Feb 2013
    San Francisco
    Default Cracked gas regulator on new stove?
    Hey there,
    Long time reader, first time poster. Anyways today I was trimming out a kitchen and while tightening a 1/2 male by flare adapter into the stove's regulator I heard a crack, I stopped tightening there and pressurized the line and sure enough the bottom of the pressure regulator had a crack along the female threads. Upon removing the flared adapter I noticed that my pipe dope had only reached about 1/2 way into the fitting and while I was tightening I felt like the adapter was still somewhat loose (I do not believe I was excessively over tightening). Anybody ever seen this? Could the casting on the regulator be faulty? I'm gonna have to swap out the regulator either way (which will be a nightmare) but was just wondering so as to avoid this in the future. I can recall one time that I had a brass 1/2" ball valve crack but never seen or thought it was possible for a regulator.
    Often, the gas fitting is a flared fitting which doesn't need to be super tight. If it is a tapered thread, then yes, tight shouldn't be a big deal. If it's a flared fitting, it technically, doesn't need any pipe dope, but you could put a little on the flared face - none needed on the threads.
    Feb 2013
    San Francisco
    The flared side of the 1/2" MIP by 1/2" flare fitting was not threaded into the regulator, was the normal 1/2" IP male threading into the 1/2" female inlet to the regulator.
    Sep 2009
    Seattle. WA
    Regulators usually made of aluminum or some kind of pot metal = soft as hell = don't tighten like you would on steel. Watch out for the chintzy brass
    gas shutoffs too, I've had to repair a few of those that got split by plumbers tightening up a nipple too hard.
  1. Stove Problem
    By Cookie in forum HVAC Heating & Cooling
    Last Post: 05-17-2011, 09:50 AM
  2. Concern regarding GAS Cook stove???
    By 77TEXAN77 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-27-2010, 04:07 PM
  3. Cost to have gas line ran to stove?
    By enviroko in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-18-2007, 07:27 PM
  4. Moving a stove
    By Bassman in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-07-2007, 07:13 PM
  5. relocating stove
    By zenrgie in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-19-2005, 08:40 AM
