Results 1 to 6 of 6
Thread: Water pressure is not constant
    DIY Junior Member Scottnot so handy's Avatar
    May 2013
    Michigan
    Default Water pressure is not constant
    Good Morning and hello,
    Fairly new to this forum but after reading some awesome articles it is now in my favorites!
    Anyway I am hoping you guys can give me some advice. As my name states I am not very good at being a handy man but it is not from lack of effort!
    Anyway my problem is my water pressure through out the house goes up and down. Doesn't matter day or night. Also I noticed yesterday while I was in the basement a switch (assuming water pump switch) would keep clicking when the water was running. It would click twice, one right after another, then stop for about 30 seconds and start again. Also the copper pipe attached to the pressure tank vibrates alot every time it clicks. This goes on for awhile then it shuts off.
    back ground information
    I am on a well
    I recently had the hot water heater replaced ( 2 weeks ago)
    I replaced the pressure tank about 10 years ago.
    Hopefully this is enough to get some advice from you guys.
    Thanks in advance!!!
    Feb 2011
    NW Ontario, Canada
    Quote Originally Posted by Scottnot so handy View Post
    Not really.
    What kind of pump, jet or submersed? What is the pressure guage showing through all that? Have you checked the precharge on the bladder?
    From the sounds of it, it may be too late to save the pump. It sounds like it is short cycling and the thermal overload is tripping.
    Pump cycling on and off? That is usually a sign of a "waterlogged" pressure tank so you are operating on "pump pressure" which will rise and fall as the pressure switch turns the pump on and off.
    May 2013
    Michigan
    Thanks LL and hj
    I will go home at lunch and check the pressure. Not sure what kind of pump it is, is there a way to tell what kind you have?
    Can I drain the water out of the pressure tank?
    Thanks again
    quote; Can I drain the water out of the pressure tank
    Depending on the type, you may just have to put air INTO it, but there is a specific process to do it. If you depress the air valve and water comes out, then you need a new tank.
    May 2013
    Michigan
    HJ, you where right, it was the pressure tank. Tank was completely full of water. Installed a new one and the water pressure is good!
  1. Grundfos Constant Pressure System Issues--Fluctuating Pressure
    By Alan Adamson in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-15-2011, 08:56 AM
  2. VFD's, CSV's, Constant Pressure Pumps, Constant Pressure Valves
    By Terry in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-05-2009, 02:58 PM
  3. Water stagnation in constant pressure tank?
    By KingAirEvac in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-26-2007, 07:53 AM
  4. constant flow control rather than constant pressure
    By mbartosik in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-28-2007, 08:44 AM
  5. Constant water pressure issues
    By PAberts in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-19-2006, 12:47 PM
