Results 1 to 4 of 4
Thread: Old vs New Solder compatability.....
    DIY Member rfsmith48's Avatar
    Feb 2008
    Colorado
    Default Old vs New Solder compatability.....
    Folks,
    I am remodeling a bathroom built in 1971. I believe that all the copper supply plumbing was assembled using Lead/Tin solder.
    If I have to resweat some of the existing joints with the current solders...(Indium/tin?) will that work?
    Because I am moving the Vanity and John, I will need to cap several lines and re-route several others.
    Can I get small amounts of the Lead/Tin solder for maintainence/repair? (I have not seen Lead/Tin solder in the stores for many years.)
    What say the Terry Love guru's?
    TIA,
    Rog Smith
    As long as you clean the pipe and fitting, use an appropriate flux, you can use the legal solder without issues on an older pipe or fitting. Once a fitting has had water run through it, you have to take it apart anyway to resolder it...just wipe off as much as you can (which will make it go into the fitting easier) when taking it apart. I'd use new fittings, but you can reuse the old ones, but it's often more hassle than it's worth. Much easier to clean and flux a new one.
    Sep 2009
    Seattle. WA
    Lead/tin solder is still used and sold, some places just don't stock it in the plumbing supply dept., although I'm pretty sure
    it can still be used on copper DWV piping.
    Just wipe the "hot" solder off the tubing with a rag and then use new fittings with the proper solder. IF you do a good soldering job you will not have any problems.
  1. Solder over existing solder?
    By breakpoint in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-26-2011, 06:18 AM
  2. pex compatability
    By rpmac in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-21-2010, 08:05 PM
  3. Toto Unifit compatability question
    By wot2000 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-24-2009, 09:42 PM
  4. taco 007 flange compatability
    By bharbwyr in forum HVAC Heating & Cooling
    Last Post: 11-05-2008, 09:10 AM
  5. gpm compatability
    By pkirkes in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-03-2006, 07:42 PM
