Results 1 to 9 of 9
Thread: Make metal glow with electricity
    DIY Junior Member carlo1's Avatar
    Feb 2013
    new york
    Default Make metal glow with electricity
    I'm a sculptor with some electricity experience; I wonder if someone can help me in this project I would like to do. I want to make a small metal object (a hand) and with electricity make it glow incandescent . Thank you if someone can help me
    Carlo
    The only way I know of to make something glow like that is to make it extremely hot, which, depending on the material, may not last very long, and wouldn't be particularly safe. You could paint it with a florescent paint and use a black light. You could get it to arc, most likely from a finger or two if you used a Vandergrift (sp?) generator, but it would need some other metal object nearby to arc to.
    Maybe someone else will have some ideas...
    close, it's Van De Graaff generator. You would have to heat it to about 3,500 degrees and by that time it would probably be melted, or oxidize unless it was in a vacuum like a light bulb's filament.
    Mar 2011
    Long Island, NY
    Quote Originally Posted by carlo1 View Post
    Carlo
    Thomas Edison did that years ago. Sorry, couldn't "resist" that pun intended, lol
    Jun 2007
    North Carolina
    Ever think about a spot light?
    To heat enough to glow using electricity will melt the metal unless it is in a vacuum.
    The paint suggestion sounded pretty good.
    Mar 2011
    Houston, TX
    Quote Originally Posted by BobL43 View Post
    Thomas Edison would be pissed to find out that his work was now being outlawed.
    Even the easy-bake oven has a heating element now a days.
    The Light bulb was more funner, but was not included for some reason.
    I have melted the glass on a light bulb and reformed the glass with a soldering torch.
    Maybe you could form a hand with glass and make your own light bulb, Vacuum and all.
    LEDs are good for lighting things up. You can use hidden batteries with no external wires.
    Have Fun.
    Don't forget the fuse.
    In the Trades dwindle's Avatar
    Nov 2012
    North East Pennsylvania
    You could encapsulate it in glass, and fill it with neon.
    But it's not exactly a do-it-yourself project.
    Mar 2011
    Houston, TX
    Do we have a Troll ?
    How about Glow in the dark paint and charge it using a incandescent light.
    DIY Senior Member Hairyhosebib's Avatar
    Jun 2010
    Arizona
    Hi Carlo,
    You might think about resin or some kind of rubber. You could consult with Polytek or Smooth-on. They make all kinds of materials for movie props and making body parts that can look real and probably glow too. Hope it helps. There might be a dealer near you that could help you out.
  1. Dim Glow in Incandescent Bulb When Touched
    By Alexsis Miller Veal in forum Electrical Forum discussion & Blog
    Last Post: 03-30-2013, 02:19 PM
  2. Rheem 04EAUSR. Igniter doesn't glow.
    By Rickcusaf in forum HVAC Heating & Cooling
    Last Post: 01-06-2012, 02:10 PM
  3. electricity and death
    By jwelectric in forum Electrical Forum discussion & Blog
    Last Post: 01-03-2011, 12:46 PM
  4. Electricity is out in a bathroom
    By milik in forum Electrical Forum discussion & Blog
    Last Post: 12-28-2007, 02:28 PM
  5. Toilet flange that is PVC & Metal (metal is Rusted)
    By Donnaml in forum Toilet Forum discussions
    Last Post: 01-22-2006, 07:45 AM
