Results 1 to 6 of 6
Thread: Wheelchair access and which Toto toilet model would work
Hybrid View
    DIY Junior Member maggiepassel's Avatar
    Feb 2013
    Atlanta
    Default Wheelchair access and which Toto toilet model would work
    We are selecting a Toto toilet for a guest bath and need to find the model which will allow the most room for a wheelchair. We need the shortest length from the back wall to the end of the seat, an elongated seat. We would like the best flushing, with sanagloss finish and 1.28 or dual flush. Any suggestions? Thank you.
    DIY Member Gordan's Avatar
    Feb 2013
    SE PA
    If you're in the middle of a large remodel and modifying the plumbing is not out of scope, you might want to look at a wall-mounted toilet with a concealed tank such as a CWT418FG. They stick out about 21" from the back wall, and you can adjust the bowl height to be anywhere from about 15" to about 19".
    But they do require room in the back wall, and are probably not a practical option if you're not doing major surgery already. The carrier Toto supplies requires a 2x6 wall but you could also get a bowl from Toto and a different Geberit carrier that'll fit inside a 2x4 wall.
    Feb 2013
    Atlanta
    Thank you for the idea. 21" out from back wall would be great. Wow - putting the tank in the wall is a great idea and we are repainting the room and adding a small half wall beside the toilet already. That is a whole other direction. We had already been quoted about $350 to install a regular toilet because of having to move the water supply line (unfinished basement below and refinishing floors also) and our walls are 2x4's so I wonder what it would cost to install this type of toilet. And, I guess if there were problems or parts wore out it would be a big deal? tearing out the wall? Any other comments appreciated.
    Apr 2012
    New York, NY
    The replaceable parts are accessible through the plate that covers the push buttons that flush the toilet; no need to remove the wall to fix stuff.
    Feb 2013
    SE PA
    The biggest issue with those is likely to be whether there's anything running through the wall behind the toilet that would prevent its installation. The more things you move around, the more it'll cost. One thing you would definitely need to move is the drain. The closet flange on the floor would have to be removed and the drain would have to be routed up the wall. Depending on what the plumbing layout looks like, this could be fairly trivial or a nightmare. So don't thank me yet. :-)
    Feb 2013
    Atlanta
    ok, I think this is more than we bargained for and will just try to find a floor mounted model with the shortest distance from the back wall. Thanks.
  1. Any Toto toilet model we can use with current waterlines?
    By maggiepassel in forum Toilet Forum discussions
    Last Post: 02-17-2013, 06:29 PM
  2. Toto toilet fill valve & model #
    By susieq29 in forum Toilet Forum discussions
    Last Post: 11-14-2012, 05:01 PM
  3. where can i find the model # on my toto toilet?
    By bakchoi in forum Toilet Forum discussions
    Last Post: 10-25-2007, 05:10 AM
  4. How to determine model of 2-year-old Toto one-pice toilet?
    By jch in forum Toilet Forum discussions
    Last Post: 01-24-2006, 10:08 AM
  5. Toto toilet model numbers
    By Dchall_San_Antonio in forum Toilet Forum discussions
    Last Post: 01-17-2006, 06:20 AM
