Results 1 to 9 of 9
Thread: Replacing DW - discovered 1/4" PEX under sink?
Hybrid View
    DIY Junior Member Cross-Eyed Cat's Avatar
    Feb 2013
    GA and NC
    Default Replacing DW - discovered 1/4" PEX under sink?
    Hi All,
    I'm awaiting delivery of a new dishwasher, and was looking to see what I would need to make the swap. Instructions for the new one call for a 3/8" OD supply line. When I looked under the sink, I found that coming up from the floor are what I believe to be 1/2" CPVC lines. Hot side is topped with a Brass Craft stop, which is then immediately topped with a brass tee that sends a 1/4" PEX straight up to the faucet, and another 1/4" PEX to the left for the DW. (Photo attached).
    Is 1/4" PEX normal for a kitchen sink faucet supply? Seems too small?
    Is there any easy way to tell what the size of the outlet side of the top is? If it is 3/8, then I presume I could get a 3/8 x 3/8 x 1/4 tee and leave the faucet at 1/4 while upsizing the DW line. But if that outlet is only 1/4, would I be stuck with having to replace the stop? THAT would make me nervous, as this is coming up from a slab and I DEFINITELY do not want to break anything near the concrete level, especially since the old DW worked fine with everything as-is ... so, maybe I'm just making unnecessary work?
    Any advice appreciated!
    Susan
    In the Trades mtcummins's Avatar
    Jun 2010
    Pittsburgh PA
    Looks like you have a tee with 2 3/8" compression fittings. The best thing to do, IMO, is remove both of these water lines and buy yourself the appropriate length braided stainless steel flex connectors. You can find them labeled in the home store for a dishwasher and for a faucet. Usually the only 2 variables will be the connection size to the shutoff (either 3/8" or 1/2", most, including yours from the look of it, are 3/8"), and the length of the line. If its labeled for a dishwasher, it should have the appropriate end connection or an adapter to make the connection to the d/w. The faucet end of those lines is standard size, any that's labeled for a faucet should work. Just don't get one of the "toilet" ones or something and you'll be fine.
    DIY Junior Member hhplumbing's Avatar
    Oct 2012
    Victoria, BC
    As mtcummins said, I would pick up a DW braided supply (we normally sell the brasscraft B1-72DW 6ft line). Now from that picture that really looks to be a 3/8" retro tee and if it is, all you need to do is take off the pex line going to the DW and thread on the braided supply by taking off the nut and metal sleeve.
    HouseHold Plumbing Forum - Reviews and how to solve your plumbing problems . Our Journeymen Plumbers will help you out anyway we can before hiring a costly plumber when its not needed.
    Visit http://www.householdplumbing.com sign up today and get your problems solved.
    Feb 2013
    GA and NC
    I know those look like they might be 3/8", but the PEX lines coming out of them have 1/4" printed on them, which is why I am thinking that they are 1/4" -- in which case, I can't attach a 3/8" flex, right?
    Susan
    Aug 2009
    South*East
    There 1/4" ID and 3/8" OD.
    John
    Feb 2013
    GA and NC
    OH! Thank you so much!! A little ignorance goes a long way. That makes everything so much simpler. I would like to add a separate shutoff for the DW so I won't have to lose the hot water in the sink just to isolate the DW, but looks like I can do that right at the tee by adding a 3/8" straight 1/4-turn stop to the left.
    Susan
  1. replacing shower body--what does "supply building with main shutoff valve" mean?
    By dayexday in forum Plumbing Forum Discussion & Blog
    Last Post: 10-03-2012, 10:29 AM
  2. 25"x22" Stainless drop-in sink in 27" sink base cabinet?
    By John414 in forum Plumbing Forum Discussion & Blog
    Last Post: 08-28-2010, 08:12 AM
  3. Need some advice on replacing a "shower kit"
    By DIYNeophyte in forum Shower & bathtub Forum & Blog
    Last Post: 12-15-2008, 09:06 AM
  4. 60" x 42" bathtubs with large base? (Replacing a tub-shower)
    By areacode514 in forum Shower & bathtub Forum & Blog
    Last Post: 08-17-2008, 08:46 PM
  5. discovered 2 holes in the 3" copper vent
    By rehabclone in forum Plumbing Forum Discussion & Blog
    Last Post: 03-28-2005, 03:06 PM
