Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
Thread: Does Undermount bath sink need more support?
  1. #16
    quote; Our last under mount sink.
    I really hope those chains were not the only thing holding the sink in place.
  2. #17
    Jul 2009
    North Vancouver, BC
    HJ we used a bead of clear silicone as well. The strapping holds the sink tight while the silicone sets up.
    These approach gives us slight adjustment of the sink and a two fold anchoring system (mechanical and chemical).
    Kitchen sinks the same way. Never used another system in the last 10 years. never gone back for a failure.
    I have fixed many other sinks that used clips and blocks before. This is so basic and so strong. Easy as pie.
    JW
  3. #18
    DIY Junior Member Dr.Guacamol's Avatar
    Feb 2013
    California, USA
    Default oops
    CanOWorms idea seems to make sense (I'm assuming you meant about "L" brackets to support the sink.)
    But often the areas to mount to have thin "wood" material to mount to. - like the cabinet back often being 3/8" thick at best.
    It's great that JW's method has worked over time. But metal does stretch. But I guess not here?
    Before, when I was trying to write a possible solution, I erroneously wrote 8' of tubing when I meant 8". I also wrote "double wall" when I was just trying to describe some thick tubing that could bend, but once bent, would resist compression on the widest diameter from the bend (because of the bend). But really any material that would mold into that area but then would not compress or crack the sink would do. [I was trying to say like ones you see with a layer of synthetic fibers seemingly sandwiched between two layers of black rubber . - commonly for water systems that use pumps.]
    Tell us what you've ended up doing. .. or having contractor re-do.
  4. #19
    Jul 2009
    North Vancouver, BC
    The silicone is the holding power in this sink installation method. Silicone is incredibly strong and does a great job by itself. The mechanical strap tie is there as back up and not installed so tight that it applies any pressure on the marble.
    JW
  1. undermount kitchen sink
    By pitterpat in forum Remodel Forum & Blog
    Last Post: 01-31-2012, 03:06 PM
  2. kitchen sink: trying to find off center drain undermount sink
    By belzoid in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-29-2010, 06:00 PM
  3. How to Remove an Undermount Sink
    By hmf-ny in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-07-2007, 07:51 PM
  4. Undermount Sink
    By jwelfeld in forum Remodel Forum & Blog
    Last Post: 07-10-2007, 11:25 AM
  5. cutting opening for undermount sink
    By Darren in forum Remodel Forum & Blog
    Last Post: 12-03-2005, 10:55 AM
