Thread: Best way to connect 1/2" PEX to 1/4" copper
    DIY Junior Member schloske's Avatar
    Feb 2013
    PA
    Default Best way to connect 1/2" PEX to 1/4" copper
    I am attempting to hook-up a water line from our water filter to a refrigerator. The refrigerator already has a 1/4" copper line connected to the refrigerator that runs about half way to the water filter. The water filter has a 1/2" PEX output (currently to a sink water dispenser). I need to add a tee to that line, then run PEX to connect to the copper. At some point I have to reduce from 1/2 to 1/4. I was originally looking at Sharkbite, but they don't have a 1/2" to 1/4" reducing coupler. Watts quick connect does have a 1/2 to 1/4 reducing coupling, but for some reason, those don't seem as robust as Sharkbite. I don't want a flood. Any recommendations? Any help is much appreciated!
    In the Trades Jerome2877's Avatar
    Aug 2009
    BC
    Install a shut off valve off of the pex t. This will bring it down to 3/8", then run 3/8" pex to the fridge and connect to the copper with a 3/8"x 1/4" compression coupling.
    Feb 2013
    PA
    Thanks for the reply. I actually already have a shutoff valve installed on for the line feeding the water filter, so that isn't necessary. I am hoping to use primarily push-fit fittings for ease and because I have terrible luck with compression fittings. I'm just having trouble finding the appropriate reducing connections.
    Compression fittings for pex almost always require an internal reinforcement sleeve, but if you do use them, it should be easy to find the proper reduction fitting. Those sleeves are typically SS, but on the smaller sizes, they may be plastic.
  1. Can't connect "simple" push-in Faucet connection
    By Santa C in forum Plumbing Forum Discussion & Blog
    Last Post: 10-19-2011, 10:35 AM
  2. Is It Okay To Spray "Great Stuff Foam" Around Copper Pipe and Copper Fittings?
    By turbocruiser in forum Plumbing Forum Discussion & Blog
    Last Post: 11-01-2010, 11:57 PM
  3. Should I connect a 3" or 4" flange to 4-in drain pipe?
    By Fistor in forum Plumbing Forum Discussion & Blog
    Last Post: 08-25-2008, 06:28 AM
  4. how to connect plastic shower drain to 2" copper drain line?
    By showerpain in forum Shower & bathtub Forum & Blog
    Last Post: 01-31-2007, 08:36 AM
  5. connect 2" washer standpipe to 4" pvc drain
    By saccof in forum Plumbing Forum Discussion & Blog
    Last Post: 11-04-2005, 04:47 PM
