Results 1 to 2 of 2
Thread: Takagi TK3 Heating Intermittently
    DIY Junior Member jon.hillegeist's Avatar
    Feb 2013
    Default Takagi TK3 Heating Intermittently
    My tankless water heater is about 6 years old. We use it for radiant heat. I haven't used it much these season, but started too this week. At first the water pump would be on, but the water wasn't circulating. The water pressure gauge was at zero. I filled it up more, and now when it comes on, the water circulates and the pressure is about 15 psi.
    But, sometimes when it comes on and the water circulates, the heater doesn't ignite. If I flip the power off and then back on. a gurgle noise will come from the heater and it will turn on sometimes.
    Any thoughts?
    It sounds like you have some air trapped in the pipes. This can cause an air lock. Does the system have an air extractor? If so, does it work?
  1. Takagi Flash T-K2 intermittently not heating
    By fmack12 in forum Tankless Water Heater Forum
    Last Post: 07-18-2012, 02:40 PM
  2. Floor Heating with Takagi JR.
    By dln7953 in forum Tankless Water Heater Forum
    Last Post: 02-20-2012, 06:09 AM
  3. Gas heater shuts down intermittently
    By batass in forum Tankless Water Heater Forum
    Last Post: 03-28-2008, 08:38 AM
  4. Gas heater shuts down intermittently
    By batass in forum HVAC Heating & Cooling
  5. Breaker Tripping Intermittently
    By sawmkw in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-05-2008, 08:24 PM
