Thread: Is it possible to rotate the flange?
    DIY Junior Member wood_pusher's Avatar
    Feb 2013
    Knoxville TN
    Default Is it possible to rotate the flange?
    The old one is kind of rusty and I don't think it will budge more than 1/4 inch as someone said on another question....but would it be possible to put a new flange in? We'd like to rotate the toilet 90 degrees if possible.
    Jan 2008
    There are possibilities, some of which would depend on what materials the pipe and flange are, and what the layers of the floor consist of.
    Code requires 15" clearance from the centerline to either side of a toilet. Given (most common) the flange is 12" from the wall, turning it without moving it would not be code compliant since it would only be 12" to the wall. Anything's possible, it just depends on what's there, and how much you want to spend.
  1. Rotate exhaust vent on new propane boiler install?
    By thebordella in forum HVAC Heating & Cooling
    Last Post: 12-10-2011, 02:09 AM
  2. Rotate toilet after it has been set
    By Yankee1423 in forum Toilet Forum discussions
    Last Post: 04-03-2011, 08:23 PM
  3. Rotate toilet flange?
    By rrdavis in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-29-2008, 10:55 AM
  4. Toro Mini 8 sprinkler head will not rotate
    By bbbluueyes in forum Irrigation / Sprinkler Forum
    Last Post: 06-29-2006, 07:58 PM
  5. rotate a pump how?
    By tomshorse in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-13-2006, 03:41 PM
