Results 1 to 2 of 2
Thread: Subfloor
    DIY Junior Member JTlikestobuild's Avatar
    Feb 2013
    Vancouver BC
    Default Subfloor
    Is the 1 1/4" thick sub floor rule of thumb under a tile/stone floor necessary if the floor joist are on 12" centers
    Instead of using 2 sheet of plywood and spending the time to screw and glue I'm thinking of using one layer of 1" plywood.
    One failing I can think of is more deflection at the ends but this can be solved with some blocking.
    I had the joist engineered for deflection (L/1000) rather than just the live/dead load. Deflection along the length of the joists is not a concern.
    Don't want any deflection in the plywood between the joists.
    Industry standards call for a minimum of 5/8" ply. Most pros don't like to use the minimum, so 3/4" is better. This is for ceramic...natural stone REQUIRES a second layer. The industry standards do not call for gluing the second layer. While it can be done, it requires a full spread of a wood glue (not something like construction adhesive from a tube) and proper fastener use and layout. BTW, all ply used for this must have NO 'D' faces, and have exposure I or exterior rated glue.
  1. Tub on subfloor?
    By _mike_ in forum Shower & bathtub Forum & Blog
    Last Post: 12-09-2012, 06:01 PM
  2. Subfloor thickness
    By ingeborgdot in forum Remodel Forum & Blog
    Last Post: 06-08-2010, 08:53 PM
  3. OSB for Subfloor?
    By molo in forum Remodel Forum & Blog
    Last Post: 04-09-2009, 06:00 PM
  4. DRICORE subfloor
    By ctkeebler in forum Remodel Forum & Blog
    Last Post: 04-23-2008, 12:26 AM
  5. subfloor -- toilet
    By pman in forum Remodel Forum & Blog
    Last Post: 10-05-2004, 06:31 AM
