Results 1 to 2 of 2
Thread: Help for Pop-Up Drain for Jacuzzi
    Default Help for Pop-Up Drain for Jacuzzi
    We are redoing our master bath and used all Kohler fixtures in Vibrant Brushed Bronze. We have a Jacuzzi tub and the measurement for the horizontal pipe is 17 5/8". Jacuzzi doesn't have a color match to the tub - oyster or the bronze. Kohler doesn't make anything with that long a horizontal measurement. At this point we will take anything close and even use a manual drain that can be adapted for the length. We just need the overflow and drain to be a close match to the other fixtures. Any help would be appreciated. - update mountain plumbing.com does custom finishes and has the manual drain and overflow
    Plumber, Contractor, Attorney LonnythePlumber's Avatar
    Wichita, Kansas
    Default Tub Strainer Finish
    The length of the shoe and the color of the strainer finish are two separate issues. You can add a piece of tubular pvc to extend the drain into the tee. I have not found a bronze finish for the waste and overflow strainers and activation fitting at the trip lever opening.
