Results 1 to 7 of 7
Thread: Washer drain and sink in basement
    DIY Junior Member rosem637's Avatar
    Jan 2013
    Michigan
    Default Washer drain and sink in basement
    Want to setup the washer/dryer/laundry sink in my basement. Does the below setup look good to go?
    Jan 2013
    Michigan
    or drain sink into the washer branch
    Jan 2013
    Michigan
    what about this get rid of the laundry tub and put in a toilet and lav sink. Use the lav drain as a wet vent for the toilet??
    Oct 2011
    Quote Originally Posted by rosem637 View Post
    In the picture abovein post #3 why do you have the toilet drain running toward the west-southwest into the washer branch then into the main when the shorter distance is to the southeast directly into the main.
    attached a compass rose for the navigationally challenged
    How many more possibilities can you come up with? They are all "proper", but not necessarily the "best" designs. In fact, there are MANY ways it could be done properly, not just the ones you show, so it is a personal preference how you do it. The compass rose is immaterial in an isometric drawing, unless it is also "skewed" to show the pipe direction, The angles are mostly 30 and 60 degrees so there is no "southeast" diriection.
    Jan 2013
    Michigan
    Quote Originally Posted by Hammerlane View Post
    because I can use the lav sink as a wet vent. if I go to the SE as you say with the toilet drain I still have to vent the toilet.
    Jan 2013
    Michigan
    yes many different ways to do this
  1. Design Plans For Utility Sink And Washer in Basement
    By essjay in forum Plumbing Forum Discussion & Blog
    Last Post: 11-15-2012, 09:36 AM
  2. Adding a washer drain to main drain in basement....
    By phantomvs in forum Canadian Plumbing Code Questions
    Last Post: 07-18-2012, 02:49 PM
  3. Basement washer/utility sink drain problem
    By jwumpus in forum Plumbing Forum Discussion & Blog
    Last Post: 03-30-2011, 11:47 AM
  4. put in my own basement sink, forgot a vent for the washer ptrap
    By majorwoo in forum Plumbing Forum Discussion & Blog
    Last Post: 11-21-2009, 08:11 AM
  5. Washer in basement-drain
    By jmailer in forum Plumbing Forum Discussion & Blog
    Last Post: 09-02-2009, 07:02 AM
