Results 1 to 7 of 7
Thread: New home with rough in
    DIY Junior Member fragment's Avatar
    Feb 2013
    Alberta
    Default New home with rough in
    I bought a new home two years ago. The builder was going to finish the basement, and the house was already framed and roughed in with the concrete poured. Given that he was planning on finishing the basement, but I asked him not to; I assume the rough in is correct for the basement bathroom.
    Here's my question, I want to finish the basement, including the bathroom, but I'm not 100% sure about a couple of things. I'll hire a plumber if I have to, but I prefer to DIY whenever I can (I like the chance to learn something new).
    I plan on putting a shower in at the back, then the toilet, then a sink. Not shown is a 2" vent line coming from the ceiling, roughly above the sink location.
    I plan on connecting the sink and the shower to the vent line and call it good. I'll need to put a trap under the sink of course, and there is a P trap under the gravel where the shower is to be.
    Other then not being certain of what's under the concrete (going on faith that the builder did it correctly), does anyone see any show stoppers?
    Steve
    In the Trades mtcummins's Avatar
    Jun 2010
    Pittsburgh PA
    Just a note before I forget, you should keep that sink line capped, you're letting sewer gasses into your home.
    We can't tell from the picture where the main stack is, which has to be functioning as the toilet vent in this setup. If its too far away from the toilet, or if the sink/lav drains tie into it wrong underground, you could have issues. There's not really any way to know that though.
    Make sure there's no trap under the concrete on that sink drain. It would be stupid, but you'll find things like that sometimes. dump a bunch of water in there, then look down it with a flashlight. if you see water, there's either a trap, or a clogged pipe down there. If no water, you should be good to go, and install your standard lav P-trap off the riser to the vent, and tie the shower vent over to the lav vent at least 42" above the floor.
    Feb 2013
    Alberta
    Quote Originally Posted by mtcummins View Post
    Thanks for the feedback. When I pour water down the sink, it all goes away so no under floor trap there. The main stack is just behind the wall to the right. I'd say five feet away. The shower drain pipe points toward the toilet drain. Seems like I should be good to go.
    this is a standard set up....the toilet and the shower are wet vented via lav drain.
    Feb 2013
    Alberta
    Quote Originally Posted by mikeplummer View Post
    Does that mean I don't need a dry vent to the shower drain? Sorry, just trying to be explicit.
    Jun 2010
    Pittsburgh PA
    Regardless of whether you need to or not, just do it. You can run into a situation where the toilet flushing can suck out the trap of the tub and let sewer gases in. It shouldn't be that difficult to get a vent on there, so why not?
    it depends if it was piped properly below the concrete...without knowing it would be safest to back vent the tub if you can
  1. Replies: 8
    Last Post: 03-19-2012, 06:47 PM
  2. Home Run Plumbing Design For New Home with far away bath
    By brianslink in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-16-2011, 07:25 AM
  3. new home
    By Ed from chicago in forum Toilet Forum discussions
    Last Post: 11-01-2010, 03:46 PM
  4. dwv in new log home, UPC
    By 69gtocv in forum UPC Plumbing Code Questions
    Last Post: 06-10-2010, 10:40 AM
  5. Home Dep*t
    By Cass in forum Lawn Care/Landscaping
    Last Post: 03-19-2007, 05:57 AM
