Results 1 to 5 of 5
Thread: Wirsbo/Uponor PEX & future work
    DIY Member DaveHo's Avatar
    Mar 2010
    SE PA
    Default Wirsbo/Uponor PEX & future work
    You can file this under "dumb questions", but would appreciate if someone(Terry?) with long term experience with the product would comment. Have you ever encountered a situation where AquaPEX which has been in service for some time fails to constrict properly after being expanded? Yes, I realize PEX-A behaves the way it does due to it's molecular make-up, etc. But lets say you have hard water or a high chlorine content, etc. Can this affect the pipe?
    I recently finished a re-plumb using AquaPEX. If I need to replace a shutoff down the road, or tie into the system is this something I might encounter?
    -Dave
    DIY Junior Member spete112's Avatar
    Jul 2012
    central Minnesota
    I have been working with Wirsbo for over13 years now. From time to time we have gotten called back to a house to change or add something. We have never had a problem taping into the original Wirsbo plumbing. I do realize that the pipe does have a little memory however mose of your memory and will come from the rings. We have never had any leaks with Wirsbo that can be blamed on the pipe. I have had leaks typing to stick the expander into a area that it did not fit and took small bites or wasted too much time shoving the joint togeter.
    I've never had problems with Uponor pipe. I picked up one of these recently
    http://www.milwaukeetool.com/power-t...rdless/2432-22
    Pretty nice
    Mar 2010
    SE PA
    Thanks for the replies. There are two spots where I temporarily used Sharkbites to connect the PEX to some existing copper. The copper will get redone when I remodel those areas at which time I'll use the proper ProPex to copper sweat fittings. Good to know I don't need to hurry to get that work done as I'm ready to take a break from plumbing after redoing the entire house.
    Terry, that tool is great. Bought one from the get-go & have not been disappointed. I couldn't imagine using the manual tool in some of the tight spots I worked in.
    I like the light on it too. Pretty nice when I'm in a dark place.
    And the expander for 1" was pretty hard on the arms. This tool makes it easy.
  1. Wirsbo / Uponor Pex Air Expander Tool
    By DavidTu in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-29-2009, 02:48 PM
  2. Pex Wirsbo uponor tool
    By hydroflow in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-23-2009, 05:46 AM
  3. Wirsbo (Uponor) fitting difference?
    By Rad777 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-20-2009, 07:31 AM
  4. Wirsbo / Uponor Installation Question
    By craigs in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-28-2008, 05:07 AM
  5. Overexpansion of ProPex (Wirsbo/Uponor)
    By OldPete in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-27-2007, 06:24 AM
