Thread: Copper water lines in my home/ shower stains????
    DIY Junior Member cross country's Avatar
    Feb 2013
    S.E. mo
    Angry Copper water lines in my home/ shower stains????
    yes I have a 2400sqrft. in-ground home...74ft. long. my point is the home was built 3 years ago and I bought this 2 yrs. ago. My problem is I have master bedroom at one end of the home with master bathroom, well where the shower is, just on the otherside of the wall is where the laundryroom is along with hotwater heater. then at the other end of my home is the guest bathroom.
    WHY DOEs my masterbath tub/shower get so much soap scum/stain and NOwhere else in the home has this problem???
    Is this from copperlines and waterheater just otherside of the wall to the shower??? only thing i can even come close to think of...but how to end this problem??? I hope this makes since. Thank you
    Plumber jimbo's Avatar
    Soap scum and mineral build up are not related to copper water lines. What "stain" are you referring to> Anything related to copper would be greenish.
    Does the guest bathroom get used daily like (Probably) the master bath does?
    The actual soap, shampoo, and conditioner used can make a big difference in how much scum is left as does how hard the water is. Have you had your water tested for hardness? Do you have a water softener?
    In the Trades Jerome2877's Avatar
    Aug 2009
    BC
    Could be a galvanized nipple for the spout that is coroding. Switch it with a brass nipple if thats the case.
  1. Is PEX at home depot or lowes okay for install under my trailer for all water lines?
    By dp200 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-07-2013, 05:26 PM
  2. How do I tap into copper water lines?
    By bassadict69 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-19-2010, 06:16 AM
  3. Tapping into sewer & Water lines of our home. Help!
    By junkk27 in forum Remodel Forum & Blog
    Last Post: 03-03-2008, 04:00 PM
  4. How long do copper water lines last?
    By jod78 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-16-2007, 04:03 PM
  5. whats causeing leaks in copper water lines
    By vamunda in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-27-2007, 03:53 AM
