Originally Posted by
ditttohead
If you are buying the house, many municipalities require a full water test. You should do that regardless to test for other potential problems. That being said, considering the low pH, low calcium, high iron... I assume you will have a high LSI. I would need the HCO3 number to really know, but... it looks fairly obvious.
A properly sized backwashing calcite filter, and you may want to chase that with a softener to remove the added harness. Iron removal equipment is highly recommended as well. Any bacteria tested? Oxygen level of the water? We need more information to make a proper recommendation. What equipment is currently in place? most iron removal medias need a higher pH, than 6.8, and some oxygen in the water. What is your current water well system? Atmospheric storage? Pressurized storage? pump capability, etc...
