Results 1 to 3 of 3
Thread: Question on venting??
    DIY Junior Member Steven Buchanan's Avatar
    Feb 2013
    Rockton, Illinois
    Default Question on venting??
    Hey everyone, I am been getting some great information by visiting this website. I found it mostly through google searches. I did have a question and I am in Illinois regarding a remodel of a 1.5 story house. On the main floor, my kitchen and the one bathroom there share a wall. The house was currently plumbed with what I believe you call a wet vent were everything is dumped down the main stack. Upstairs there was a toliet and sink only. I am expanding the bathroom and adding a shower(upstairs). I am pretty sure I figured everything out except when it comes to the venting. On the main floor, (correct me if I am wrong) I was going to run a 2" vent for the toliet, bath sink, tub and kitchen sink. My question is once I reach the attic space area I wanted to connect a couple vents before going out the roof. How far can I go horizontally to connect before I go out the roof? Also, the main stack was serving as the only vent before so can I connect to it above the fixture level(2nd floor) to utilize it as a vent? I also have a floor drain in the basement and it was connecting horizontally(first floor vent).
    Jan 2008
    A 2" vent should be fine for your new install. If you tie the vents into an existing stack, it must be above the flood rim of any fixtures which are draining into it. The horizontal section across the attic is not a problem as long as all of the vents are pitched to drain condensation.
    Feb 2013
    Rockton, Illinois
    Thank you Cheesehead! Much appreciated! I've been racking my brain the last couple weeks trying to figure this out. I am much better with electrical.
  1. Question about venting
    By lindyq in forum Water Heater Forum, Tanks
    Last Post: 02-16-2010, 10:21 AM
  2. Venting Question
    By phixit in forum Plumbing Forum Discussion & Blog
    Last Post: 12-26-2006, 09:43 AM
  3. Venting Question?
    By JB1069 in forum Plumbing Forum Discussion & Blog
    Last Post: 12-15-2006, 07:30 PM
  4. Venting Question
    By MarkJenks in forum Plumbing Forum Discussion & Blog
    Last Post: 12-13-2006, 05:17 AM
  5. Venting Question
    By MartinR in forum Plumbing Forum Discussion & Blog
    Last Post: 05-12-2005, 10:44 PM
