Results 1 to 5 of 5
Thread: 2 water heaters?
Threaded View
    DIY Junior Member karter56's Avatar
    Feb 2013
    Charlotte, NC
    Default 2 water heaters?
    I have a 3 bath home with just 3 of us living here. My main water line runs into a 30 gal gas unit. It then runs out of the 30 gal unit and into a 50 gal gas unit and then out to the house. There is a line spliced into the outgoing line over to a circulating pump and into the hot water coil at the furnace. It then comes out of the furnace and into the drain valve on the 30 gal unit.
    Do I possibly need this much hot water? Both of my units are over 20 years old and I am concerned about their lifespan. I would like to replace both units with a single if possible. Is it really a bigger draw on the water heater since the hot water is circulating through the water coil and right back into the tank?
  1. Replies: 4
    Last Post: 04-04-2011, 01:45 PM
  2. Anyone know anything about these new GE Geo Hot Water Heaters
    By dpete3 in forum Water Heater Forum, Tanks
    Last Post: 11-16-2010, 05:27 PM
  3. HD Water Heaters
    By Cookie in forum Plumbing Forum Discussion & Blog
    Last Post: 08-08-2008, 04:55 PM
  4. Does a dual water heater installation require that the water heaters be the same size
    By GooSkinBaldi in forum Plumbing Forum Discussion & Blog
    Last Post: 04-29-2007, 02:28 PM
  5. GE water heaters
    By Cass in forum Plumbing Forum Discussion & Blog
    Last Post: 08-13-2006, 08:30 AM
