Results 1 to 5 of 5
Thread: well not starting
    DIY Junior Member Ellis's Avatar
    Feb 2013
    Texas
    Default well not starting
    My well will not start,it just makes a humming sound.It is a submersible pump with a Square D pressure switch and a Franklin Electric QD control box.I have changed out the Square D pressure switch,but still no go.Is there a way to check the Franklin Electric QD control to tell if that is what is bad?Any troubleshooting help would be appreciated thanks for your time.
    Moderator valveman's Avatar
    Mar 2006
    You can see how to check that box on the Franklin Electric web site in their AIM manual. But I would just replace it. Stick on a new box and if the pump still won't run, you probably need a new motor. That is as long as you have 240V going to the motor to start with, which I would check first.
    Feb 2013
    Texas
    Yes I do have 240 volts going to it.Thanks for the reply and info.
    DIY Senior Member craigpump's Avatar
    Apr 2012
    ct
    It's not uncommon for the control box to go bad and hear a hum when the pump tries to start.
    In the Trades Texas Wellman's Avatar
    Feb 2010
    SE Texas-Coastal
    You should be able to buy a franklin box at lowe's/HD for about $70-80 (haven't priced them lately).
    Good luck!!
  1. starting 2nd floor renovations
    By bbillcee in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-10-2010, 12:40 PM
  2. Starting Wattage?
    By silasgreen in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-01-2010, 05:04 PM
  3. New project starting
    By BJ James in forum Shower & bathtub Forum & Blog
    Last Post: 01-31-2009, 07:45 AM
  4. Starting up old well
    By David Cowley in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-30-2005, 05:39 AM
  5. Starting a major project
    By trinculo54 in forum Remodel Forum & Blog
    Last Post: 07-01-2005, 04:06 PM
