Results 1 to 13 of 13
Thread: Schedule 30 for toilet drain?
    DIY Member mar3232's Avatar
    Oct 2011
    Indiana
    Default Schedule 30 for toilet drain?
    may not want to hear the answer on this because I already ran about 16 feet of it in my crawl space but double checking.
    used that 3" PVC pipe that has the thinner wall (also a "flange" at one end where you can put 10' pieces together).
    have a nice slope and it drains very well (water anyway).
    the guy at Home Depot said I can use it for a toilet drain -- is he right ? !
    thinking about it now, I wonder if you have to use the thicker schedule 40 instead?
    actually, I do plan on using sched 40 from the toilet and then about 6 feet later, coupling to the sched 30, and doinf the same on the other end that ties to the main drain.
    Aug 2009
    South*East
    Why would you even consider using it? The difference in cost is close to nothing. How can Home Depot allow such unqualified people to represent them?
    John
    In the Trades mtcummins's Avatar
    Jun 2010
    Pittsburgh PA
    ABSOLUTELY rip all of that out and put in 40. Its not legal, not going to last, etc. That stuff is made for drainage water outside, not household waste. And its a PITA to convert back and forth between them too.
    Every once in a while you'll get a good employee at HD. They're usually the old guys, a retired plumber that needs something to do or some similar situation. If they're 30 and working at HD, there's a reason. If they knew what the hell they were doing, they'd be out doing it, not making $8/hr at Home Cheapo.
    Seriously, if you have a question when you're there, be obnoxious and ask the other customers... you know, the ones in overalls with a plumbing company name on the patch. I know I'm gonna be hated by all the other plumbers on here for suggesting such a thing, but you help people here, might as well try to save people from themselves (and the HD employees) there too. Of course most of you pros probably never shop at HD, but I do see some in there from time to time. And when I see a particularly confused shopper, I try to help out if I have a minute. Pay it forward
    DIY Senior Member Chad Schloss's Avatar
    Jun 2010
    USA
    It is legal here in Michigan. Our 2006 home used it along with Sched. 40. Would I change it over if I could? sure. This is made for household use, I have looked it up before. Genova i think is the manufacturer, or at least some of the fittings.
    Jun 2010
    Pittsburgh PA
    It MAY be legal in your area, depending on what code you use, etc. I can't really comment on that. I know that it is NOT legal where I live.
    Either way, you're in the early stages, do it right. Once its all done, you've chained yourself to an inferior product. And who wants inferior products when it comes to getting waste out of your house? Its just not worth it.
    Aug 2009
    South*East
    Quote Originally Posted by Chad Schloss View Post
    Here is a PDF of the Michigan code. Sch 30 is not allowed.
    http://ia600308.us.archive.org/26/it...i_plumbing.pdf
    John
    Jun 2010
    USA
    funny, it passed inspection in 2006 when it was built. it is sold at the big box stores locally and the pipe is labeled DWV ASTM-2949 i think
    EDIT: It's allowed per your .PDF under table 702.3
    The people who would use that pipe are the same ones who would use Orangeburg, because it was cheaper. I do not know how you would use it for a complete indoors system because there are limited fittings for it and you cannot use it with sch. 40 fittings unless you use an adapter at every joint, which quickly wipes out any price advantage. IT is permitted outdoors underground, but if you use it there, be prepared to dig it up some day when it becomes "egg shaped" and you cannot snake the stoppage in it.
    Jun 2010
    USA
    " I do not know how you would use it for a complete indoors system"
    The fittings that I see on what is installed here do not have an adapter. They use sched 30 on two ends and sched 40 on another. like I see a 3x3x2 wye and the 3" portion is sched 30 and the 2" is sched 40. Just for FYI
    Consultant cwhyu2's Avatar
    Aug 2007
    Cincinnati OH
    Just NO! Not allowed for sanitary.
    That is because they do not make "sch 30" pipe in 2".
    Oct 2011
    Indiana
    Figures.
    I have no choice but to use it for a year or so and then replace it -- no way I'm doing that crawl space &^)% again (for now) with my 60 year old body. I do have a nice slope and certainly won't put ANY chemicals, etc in it -- and flush often. Normally I don't listen to anything a Home Depot guy tells me but this was an old dude and "supposedly" a former plumber.
    Jun 2010
    Pittsburgh PA
    I hate to hear (er, rather see) myself even typing this, but if its all in and done already, you can probably just live with it. It may do you ok for a good long time, it may not. The issue is, are you ok with dealing with an emergency replacement of it down the road if it fails?
  1. PVC schedule
    By lemains in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-15-2008, 09:06 AM
  2. Schedule 40 PVC vs. Schedule 40 Foam Core
    By ROSSBYINGTON in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-10-2008, 03:48 PM
  3. Installing new Schedule 40 Bath Drain
    By mi21stinf in forum Shower & bathtub Forum & Blog
    Last Post: 04-08-2008, 07:40 PM
  4. one more ??? schedule 40 pvc
    By coach606 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-07-2006, 06:04 AM
  5. Schedule 40 PVC vs. Schedule 40 Foam Core PVC
    By Fran in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-09-2005, 09:44 AM
