Results 1 to 3 of 3
Thread: Vacuum breaker on hand held shower with dual check valve?
    DIY Junior Member KenInCa's Avatar
    Feb 2013
    California
    Default Vacuum breaker on hand held shower with dual check valve?
    We're installing a new hand held shower (Hansgrohe). The wall outlet includes dual check valves. Is there any reason we also need to (or would want to) put on a vacuum breaker? I already have it, I'm just not sure if it makes sense to use it.
    Thanks,
    Ken
    It will be easier to convince the inspector it is to code with it installed. You really don't want it sitting in the tub and a hiccup draw water into the supply and pollute it, so a secondary control isn't a bad idea. I'm not sure about the codes WRT this.
    Feb 2013
    California
    It's a stall shower, and I don't think the hose is long enough for the head to reach the pan. But since I have it anyway, I suppose it wouldn't hurt to put it on (I was going to return it if I didn't need it, but hey, what's another $35? ). Thanks!
  1. Shower and hand held 3/4 valve
    By scooterbase 001 in forum Shower & bathtub Forum & Blog
    Last Post: 12-02-2011, 03:54 PM
  2. hand held shower unit
    By TacomaJake in forum Shower & bathtub Forum & Blog
    Last Post: 03-02-2011, 05:12 PM
  3. Thermobalance III with Kohler Handshower - vacuum breaker or check valve?
    By strawberryblond in forum Shower & bathtub Forum & Blog
    Last Post: 04-05-2010, 04:55 AM
  4. Vacuum breaker on deck mount hand held shower
    By Mrikert in forum Shower & bathtub Forum & Blog
    Last Post: 06-04-2008, 05:05 AM
  5. Hand held shower only placement
    By Zubini in forum Shower & bathtub Forum & Blog
    Last Post: 04-12-2007, 11:33 PM
