Results 1 to 12 of 12
Thread: Is my new Toto SS114 toilet seat supposed to be loose and floppy? -with video-
    DIY Member stephenk's Avatar
    Nov 2012
    Plains
    Default Is my new Toto SS114 toilet seat supposed to be loose and floppy? -with video-
    I bought a Toto SS114 seat for my Drake II and it arrived today. It's made in China and very floppy. The seat's mounting flange is bolted to the bowl securely, but the seat and lid are all floppy and move independently from the mount. The seat easily moves around when in use.
    It seems there's lots of play in the hinge, allowing the seat and lid to flop side-to-side, even though the seat assembly is tightly bolted to the toilet.
    Is this normal?
    Here's a video of my new seat to show how much it moves around.
    In the Trades mtcummins's Avatar
    Jun 2010
    Pittsburgh PA
    Wow, I'm becoming less and less impressed with Toto...
    Maybe call them and see what they say, that's def unacceptable.
    Nov 2012
    Plains
    Quote Originally Posted by mtcummins View Post
    I emailed them and included a link to the video before posting this thread. We'll see what they say.
    Jan 2008
    Damn, I just ordered one of those. I hope it's not like that.
    WHat works best is the blind fasteners that probably came with the toilet. The plastic screws and nuts that come with the seat do have slop in them. The blind fasteners are plugs that fit into the hole in the bowl and when you tighten the screw, they expand. These are much more secure. Some of the toilets come with them, not all. You can pick some up at a big box store, though.
    Nov 2012
    Plains
    I don't think you understand the problem. The movement is not caused by a loose fit where the seat bolts to the toilet, that's a tight fit. The seat and lid are moving independently of the mounting flange. It seems there's lots of play in the hinge.
    The mounting flange is securely held to the toilet, but there's a loose fit in the hinge where the seat and lid connect to the mounting flange. The issue is with the way the seat is made, not how it's installed on the toilet.
    Watch the video more closely and I think you'll be able to see the issue. In the second half of the video I show a closeup of the mounting flange, which is securely held to the toilet. The movement isn't coming from the hardware supplied with the seat.
    And, this toilet didn't come with special seat mounting hardware.
    Apr 2012
    New York, NY
    Yep. That's how it works on ours. The thing is firmly mounted but there is play where it connects to the bar. It doesn't bother us at all. Interesting that it's troubling.
    DIY Junior Member tso1ab's Avatar
    Mar 2009
    GA
    We've got three of them. Initially the wiggle surprised me, but it hasn't been an issue for us. We like the seats.
    DIY Junior Member GeorgeCT's Avatar
    Apr 2011
    I just checked mine and it does the same thing.
    It is supposed to give a little so it wont snap off when you sit down.
    It's not a defect but designed that way.
    DIY Member DougB's Avatar
    Jun 2010
    Minneapolis - Land of 10,000 taxes
    I noticed the same play in our Toto seat. It's difficult to sit on the lid - down right dangerous - I think it should be more ridgid also.
    Jun 2010
    Pittsburgh PA
    I haven't used that Toto seat, but that seems like an awful lot of wiggle room, if its supposed to be like that. A little wiggle should be expected, or the hinge would probably not last long, but that is a lot.
    My Kohler (not usually a big fan, but like this seat) moves just a little, but it is solid and stable. You can sit on the lid w/o worry, or at least I can.
    Apr 2011
    I'm 180 lbs and when I sit on the seat or lid it doesn't move just from shear weight pushing down.
  1. Toto Vespin tank supposed to be loose?
    By nuke in forum Toilet Forum discussions
    Last Post: 12-23-2012, 04:35 PM
  2. Floppy toto toilet
    By Rookhawk in forum Plumbing Forum Discussion & Blog
    Last Post: 06-27-2012, 08:44 PM
  3. Toto Seat Question: SS164 or SS154 or SS114
    By Arlington22207 in forum Toilet Forum discussions
    Last Post: 01-06-2011, 11:04 AM
  4. Loose Toilet Seat Cure
    By Andrew P. in forum Toilet Forum discussions
    Last Post: 07-19-2009, 04:03 PM
  5. Toto seat loose
    By doggone2 in forum Toilet Forum discussions
    Last Post: 06-07-2009, 05:35 PM
