Results 1 to 10 of 10
Thread: A/C wiring
Hybrid View
    DIY Junior Member sandy vandehey's Avatar
    Feb 2013
    arvada co
    Default A/C wiring
    Hi, We had to have our furnace temporarily moved to replace the slab in the basement, we did not do the disconnect but put the furnace back in place, everything is fine, the heat works, but we have a red and a white wire from the air conditioner and do not know what terminals to attach them to. The terminals are TWIN, Y, G, W, R, C. We matched the terminal in the thermostat to the terminals in the furnace so the heating works. The furnace is a rheem RGDG 15EARJR and is about 19 yrs old. Thanks Sandy
    Mar 2011
    Houston, TX
    Quote Originally Posted by sandy vandehey View Post
    It could be for Low voltage Supply or it could be for Fan control.
    Wire color may not mean much, Or W = White and R = Red.
    More info could help.
    Take the cover off the a/c unit and see where they are attached. My guess is probably red and yellow, but there's no way to tell for sure.
    Feb 2013
    arvada co
    I may not have been clear, the red and white wires are from the a/c unit outside and were run into the furnace control board, they are 18 or 20 guage like door bell wire, they were connected to the terminals I identified earlier, just don't know which ones to attach them to. They connect some how to the treminals with with the wires from the thermostat which controls the heat and cooling. The a/c coils in the plenum above the furnace and the unit outside were not disturbed, they were left in place, only the furnace was moved and so the wires from the thermostat were disconnected The heat is functioning fine. Hope this helps with the question. Thanks - Sandy
    What you said was perfectly clear, but maybe I wasn't...it is highly likely that those wires control the a/c unit. Look at the a/c unit and see where they attach - probably the yellow and red. Then, follow them back and install them on the same terminals at the furnace. It is highly likely one is the 24vac common, and the other is the 24vac that gets turned on when the thermostat is set to a/c and it wants to turn on the a/c unit. This pulls in the power contactor and turns the a/c unit on. It should be clear if you view the wiring diagram on the furnace.
    Feb 2013
    arvada co
    Thanks will give it a try today Sandy
  1. Hot Tub Wiring
    By aopainter in forum Electrical Forum discussion & Blog
    Last Post: 04-09-2013, 07:04 PM
  2. Spa Wiring
    By EdGear in forum Electrical Forum discussion & Blog
    Last Post: 05-19-2009, 11:19 PM
  3. Wet Bar Wiring
    By Waterloo in forum Electrical Forum discussion & Blog
    Last Post: 12-11-2007, 02:10 PM
  4. Wiring 101
    By MLTHAND in forum HVAC Heating & Cooling
    Last Post: 11-13-2007, 03:08 PM
  5. Three way wiring
    By Jed54 in forum Electrical Forum discussion & Blog
    Last Post: 08-04-2007, 03:01 PM
