Page 1 of 2 12 LastLast
Results 1 to 15 of 28
Thread: Removing Blower to Change Anode on A.O. Smith Powershot 50 100
    DIY Junior Member DoubleEagle's Avatar
    Feb 2013
    Northern NJ
    Default Removing Blower to Change Anode on A.O. Smith Powershot 50 100
    I ordered a new aluminum anode for my 8 year old A.O. Smith Powershot 50 100 and hoped to change it yesterday. I unscrewed the 4 screws on top attaching the blower unit to the heater, removed the two clamps on the rubber transition that connects the exhaust of the blower unit (2" diameter) to a 3" white PVC tube that goes up (see pic). Name:  IMG_20130217_174949.jpg
    After doing this, however, there was insufficient space to lift the blower unit over the top of the water heater because the PVC tube was fixed and in the way; it's cemented to an elbow which goes into the ceiling and there is no wiggle room. There is also a metal bracket on top of the hole in the heater. See second pic. Name:  IMG_20130217_175002.jpg
    A friend (not a plumber) suggested I temporarily remove a 3" cross-section of the PVC tube, which will free up some room. Then I would buy a 3" to 3" rubber seal to reconnect the PVC tube when I'm done.
    Looking for the forum's suggestions on how else to proceed. Have you encountered this situation where there is no room to remove the blower? Thank you in advance.
    Jan 2008
    Cutting the PVC pipe and then re-assembling with a proper PVC coupling is one option. It might also be feasible to cut one of the copper lines and remove the pipe from the heater so that the blower can move sideways enough to get at the anode rod.
    Standard plumbing rubber banded couplings are not approved for that use. The flue gas can damage some materials. An HVAC supply might have something that is, but I not aware of one.
    The first picture shows the blower flush with the top of the heater, but the second one shows the anode rod projecting above the top of the heater. Does the blower cover the anode rod, and if so how do the two fit together. There are also anode rods that screw into the heater's hot water outlet opening.
    Feb 2013
    Northern NJ
    The blower normally sits flush on top of the heater and covers the anode rod opening. If I understand your question correctly, the blower is attached to the top of the heater by four screws. The second picture shows the blower after removal of the screws and lifted up on one side; the other side can't be lifted because of the PVC pipe pushing down on it. As a result, I am unable to get enough clearance over the anode rod to remove it. Also, the replacement aluminum rod I received was only 16"... seems short to me.
    By the way, is there a way to avoid removing the hot or cold water openings since it appears they have been soldered to the pipes above and would require re-soldering? Thanks again.
    Jan 2008
    I suppose if you were 100% against the idea of soldering, you could cut out a section of copper and then re-attach it with a sharkbite fitting when you are done.
    You are going through hoops to change an anode rod on a heater that could fail regardless.
    Feb 2013
    Northern NJ
    Not being in the trade, I had to search for what a sharkbite fitting is. I think it's a good suggestion because it would allow for future accessibility to the top of the heater (in case I need to change another anode rod if the heater lasts me another 7 years). In a "why'd they do that" moment, I do not understand how the builder expected people to change the anode rods.
    The question is whether to work on the hot or cold water pipe (and which segment to remove and replace with the coupler). Here is a picture of the hot side:Name:  IMG-20130218-00102.jpg
    The hot side looks more amenable for a straight coupler. To further prolong the life of the heater, maybe I should install an additional rod under the hot water pipe (as HJ has suggested)?
    Here is a picture of the cold side: Name:  IMG-20130218-00103.jpg
    Thanks again.
    Jan 2008
    You will have to buy not only the sharkbite, but also the removal tool if you ever plan on removing it again. The pipe copper should be cut with a tubing cutter and deburred to make sure the sharkbite fits properly and is not damaged during the install. I have a feeling this is going to be an additional investment for you.
    Replacing an anode rod is a once in a lifetime experience (in the lifetime of a heater) In my opinion, this would be a perfect time for you to learn to solder, and when you are done you will have learned a useful skill. When it comes time to change the heater, knowing how to solder will make it a 1 hour job.
    Feb 2013
    Northern NJ
    Thank you; you're right that going the sharkbite route would be additional investment. I'm open to learning how to solder. Based on the pictures of the hot and cold sides, would you apply heat to the hex nut connector and screw that off? After that comes off, I'm assuming the dip tube becomes free and is able to be unscrewed from the tank.
    On the hot side, the horizontal pipe above the 90 degree elbow actually makes contact with the PVC pipe. I'm thinking I need to wrap a wet cloth around that part of the pipe so as to not melt the PVC. Thanks.
    Feb 2005
    Cool good luck with all of this
    just my 2c worth of advice here.....
    if the heater is a power vent and it is 8 years old and it is
    an a.o.smith,,, I might suggest that you leave it alone and
    let it live out the rest of its life in peace......
    There is no guarantee that after you work your ass off and
    cut everything out of the way that you will actually be able to
    remove that anode rod from the heater........
    I have attempted to remove anode rods from much newer heaters
    only to give up in disgrace and humilation.and utter defeat...
    you better have a HUGE-- HEAVY DUTY-- socket and a HUGE cheater bar
    to get that nut to budje out of the heater.... Also you better
    have someone holding the heater in place to be sure it does not move
    when you attempt to remove that nut.....
    the socket wrench we have for this job we have nick-named THOR
    if you actully complete this mission and win, there is still no guarantee
    that your power vent water heater will spring back to life after you have
    beat around on it for an hour or two.....
    leave sleeping dogs lie....
    god created all men,
    quote; I do not understand how the builder expected people to change the anode rods.
    Because few people do it. My "replacement" for anode rods, and I only 'replace' them when they cause an odor in the water, is a 3/4" brass plug.
    Feb 2013
    Northern NJ
    Quote Originally Posted by master plumber mark View Post
    Appreciate your view and the caveats.
    And all along, I've been under the impression that replacing the anode rod is a maintenance item that would prolong the life of a heater. Do you think there would be a noticeable difference if I replaced the current anode rod AND installed another rod under the hot water port? I understand that this is the setup in certain "long-life," extended warranty heaters.
    If you got a call and encountered a setup like mine, what would you desolder and remove to get to the rod? Thanks.
    Feb 2005
    Cool knock your self out
    Quote Originally Posted by DoubleEagle View Post
    I just wont go on a call to change out an anode rod...It can become
    a manhood contest even on a brand new heater still in the box.... when they
    get older the nut just welds itself into that steel body and you dont know
    what you might cause to happen
    it can cause more trouble
    far than it is worth ... especially on a power vent unit....
    yes if you were to add an extra anode rod it is supposed to
    lengthen the life of the water heater
    your unit is like skateing on thin ice... it can be done
    but I would not do it for anyone without a huge bill and a
    disclaimor if the unit does not fire back up again
    if you are retired and dont have anything else better to
    do with your time..... and got another place to take hot showers
    in case you screw it up......
    go for it
    A power impact wrench is much more likely to loosen the anode rod without twisting things off...as noted, they can be really hard to get out. Sacrificial anodes do work, but keep in mind, it's a glass-lined tank, and after awhile, the expansion/contraction can create cracks in the lining. There's only so much an anode can do. Sometimes, the only difference between warranty length is the length/diameter or quantity of the anode rods installed during manufacturing. Sometimes, there's literally no difference except the label and the extra insurance cost.
    Feb 2013
    Northern NJ
    OK, I plan on using an impact wrench (as I understand that is how the anode rods are installed from the factory). I just need a step-by-step on which pipe to desolder or remove... can anyone walk me through based on my setup?
    quote; Sometimes, there's literally no difference except the label and the extra insurance cost.
    When the difference between a 6 year tank and a 10 year one is the cost of the certificate and a replacement name plate, I guess that means there is NO physical difference.
  1. Replies: 6
    Last Post: 10-09-2012, 02:26 PM
  2. AO Smith GPSH 50 100 Anode replacement
    By Dshow in forum Water Heater Forum, Tanks
    Last Post: 09-16-2012, 06:20 AM
  3. Anode rod replacement on AO Smith Heater
    By ktvaughan in forum Water Heater Forum, Tanks
    Last Post: 09-25-2010, 08:26 PM
  4. Replacement Anode for AO Smith
    By Kevin in Michigan in forum Water Heater Forum, Tanks
    Last Post: 06-01-2010, 04:21 PM
  5. Anode Rod Access location for AOSmith Powershot
    By BobW44 in forum Water Heater Forum, Tanks
    Last Post: 06-21-2009, 05:47 AM
