Results 1 to 10 of 10
Thread: Water leaking on bottom of faucet when turned on
    DIY Junior Member SadPanda86's Avatar
    Feb 2013
    New York
    Question Water leaking on bottom of faucet when turned on
    Hi, my mom recently bought a condo and I am trying to learn as I go along. Recently the bottom of my faucet starting leaking. It only happens when I turn the cold water on. Do anyone know what is causing this?
    The red arrow is where the leak is coming over
Size:  34.5 KBName:  Sink.jpg
Size:  24.6 KBName:  Bottom.jpg
    there are at least 3 possibilities, but we would have to be there to sort them out, or see it was something else entirely. So are doctors and dentists, but if you needed one, you would go to them.
    Feb 2013
    New York
    What are the 3 possibilities?
    Remove the cold handle of the faucet. Now put the handle back on and turn the cold water on. While the cold water is running into the lavatory lift the handle off of the stem and inspect for leaks.
    If you find leaks then repair them.
    Feb 2013
    New York
    So I replaced the faucet stem and seat but the problem persist. Does this mean that I need to replace the whole faucet?
    Jan 2008
    The aerator may be leaking past the threads and back into the faucet body.
    If you keep buying all of the component parts, you will have exceeded the value of the faucet.
    edited to add- I see now that it only happens on the cold side. Aerator would leak regardless of hot or cold.
    TROJAN WORLDWIDE SALES RP MACPLUMB 777's Avatar
    Aug 2007
    Houston, Texas, United States
    Don't turn cold side on and it will not leak !
    MACPLUMB 777
    E-MAIL
    JERRYMAC@TROJANWORLDWIDE.COM
    35 YEAR MASTER PLUMBER, HEATING, ELECTRIC, DRAINS, FIRE SPRINKLERS, WATER HEATER
    AND BOILERS SINCE JAN, 1989
    281-706-1631 7 DYS A WEEK SALES AND TECH. SUPPORT
    Trojan Worldwide Web Site
    Feb 2013
    New York
    sorry for the delay with update, so I have decided to get a new faucet. Do I need to get new water supply line or get I just switch the faucet?
    Plumber jimbo's Avatar
    Quote Originally Posted by SadPanda86 View Post
    The connection at your faucet looks like standard 1/2" IPS..... I say standard because it USED to be. Today, you will still find some faucets with that inlet, but MANY faucets have factory-attached flex lines, which are usually 3/8 on the end to the stop valve, in which case you will need an adapter.
  1. loud foghorn sound when hot water faucet is turned on
    By gotDIY in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-21-2009, 08:14 AM
  2. New Toilet Keeps Leaking From Bottom
    By fjordrr in forum Toilet Forum discussions
    Last Post: 11-16-2008, 06:43 PM
  3. Why is sink shutoff valve still leaking after main water valve turned off?
    By kimana517 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-18-2008, 06:28 PM
  4. Faucet Turned On By Itself
    By toddsegal in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-15-2007, 05:06 AM
  5. No hot water when faucet is turned on
    By nsghai in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-10-2006, 02:56 PM
