Results 1 to 11 of 11
Thread: Another Utility Sink Install
    DIY Junior Member TheDudeJoe's Avatar
    Feb 2013
    Las Vegas
    Default Another Utility Sink Install
    Hey guys, I'm attempting my first DIY plumbing project.
    I found this site, and have learned quite a bit, thanks so much to everyone who gives their time & advice here.
    I'm going to put a utility sink in the garage next to the laundry.
    Here's what I got;
    I've seen the example picture on a few of the threads, I guess I just want a little confirmation, is this all I need to do;
    Jan 2008
    What you have drawn in is fine as long as you install a sanitary tee above the existing one for the drain. If you are going to revent the washer, the vent take-off should be a wye and 45. The drain should be 2" and vent 1-1/2".
    You need to make sure that the sink is high enough so that when the trap is installed this will allow proper pitch to the drain.
    Feb 2013
    Las Vegas
    SO do I need to go under the washer, to have my venting be correct?
    Some codes allow the sink to wet vent over the washer, if the piping is 2"
    Or you can vent both and it passes anywhere.
    If you have the washer over the sink, then for sure they both need venting.
    Jan 2008
    DudeJoe, the problem is that there is more to it than what you think.
    Because the washer drains a high volume of water quickly, the tee for the sink should be above the tee for the washer.
    Putting the sink tee over the washer makes it necessary to install a re-vent on the washer drain to meet code in many areas.
    An additional challenge is that the sink drain and the washer drain need to be 2" Because the existing tee for the washer is only 1-1/2 inch at the top, it that existing tee will need to be replaced with one that is 2" at all 3 ports.
    You are going to need to cut out the existing tee and laundry drain and start fresh.
    Don't cut off too much or you wont have anything to connect to, and/or the washer trap will be on the floor.
    Feb 2013
    Las Vegas
    Thanks again for all the help everyone.
    Here is what I've ended up with before glueing and and going through the studs.
    The washer drain is going to be higher, I haven't figured out where I'm putting the outlet box yet, other that that, how am I looking.
    In the Trades mtcummins's Avatar
    Jun 2010
    Pittsburgh PA
    Funny how towns ravaged by natural disaster, with massive amounts of total rehabilitation, and permits/inspections to go with it, tend to lax up a bit on code enforcement. Seems they have better things to do than insist that the letter of code be enforced, such as get millions of people back in their homes.
    I'm no code-nazi. You could probably look up many posts on here where that's apparent. But in this case, there was no reason to not do it right, the access wasn't that difficult, the wall is open, etc.
    I'll let the real pros like Terry answer for sure, but what you have there looks all right to me. Make sure you get your full standpipe height on that washer drain, but you already mentioned that you know you need to do that.
    What you have there now will work, as long as the standpipe on the washer is taller. Change that and you can go ahead and glue it up.
    Max trap arm length before vent
    1.5" = 42"
    2.0" = 60"
    You can pretty much use a medium 90 anywhere except on waste going from vertical to horizontal.
    or horizontal to horizontal. Horizontal to horizontal needs a long turn. (edit)
    The long sweep on the vent is fine though.
    I quit stocking "vent" 90's with my fittings. Medium 90's can be used more places and they cost less.
    Jun 2010
    Pittsburgh PA
    Isn't a horizontal to horizontal 90 generally a long sweep situation as well? I could be remembering wrong as far as code, but I'd always do a long sweep or 2 45s in that situation if possible. I know a medium 90 is usually used for a trap arm turning out of the wall (such as in this setup), but I never use a medium 90 on its side anywhere else in the drainage system.
    I find that vent els can be handy in a few select situations, but yes, generally unnecessary extra parts.
    Jun 2010
    Pittsburgh PA
    Like the cleanout in your setup too, btw. Often skipped, but a nice thing to put in while you're working. Just be sure to leave some way of getting at it through the drywall, so you can find it when you need it
    Jan 2008
    Looking good.
    A minor detail but the horizontal section on the re-vent should be at least 6" higher than the top of the standpipe when you glue it up.
  1. Install Utility sink in laundry room
    By ncinqueg in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-09-2013, 05:20 AM
  2. Can bath sink and utility sink drain into 1.5"...PHOTOS
    By Hammerlane in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-16-2012, 01:02 PM
  3. Can I tie my bathroom sink and utility sink drains together? As well as vent?
    By vinceliberto in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-21-2010, 06:02 AM
  4. Basement remodel - bar sink, utility sink - design
    By jbrinker in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-27-2009, 09:14 AM
  5. Question on drain for utility sink install in basement
    By Fastgt79 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-14-2009, 07:20 PM
