Results 1 to 2 of 2
Thread: Replacement Shallow Well Pump
    DIY Junior Member mikep-sc's Avatar
    Feb 2013
    South Carolina
    Default Replacement Shallow Well Pump
    Hello:
    We just purchased property however someone removed the existing shallow well pump the piping that goes into the well.
    I purchased a 1HP shallow well pump from Harbor Freight and would like to know about the pipe that goes down into the well. The pump inlet and outlet pipe size is 1". One illustration shows a larger pipe going down into the well (with a foot valve) connecting to the 1" inlet pipe. Looks like a 2 or 3" pipe. My question is, am I able to continue the 1" down the well or should it be larger.
    Thanks.
    Mike
    Moderator valveman's Avatar
    Mar 2006
    Usually there is 1 1/4" on the suction and 1" on the discharge.
  1. Best shallow well pump?
    By steve2278 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-22-2010, 06:37 AM
  2. Can a Myers deep well pump be used as a shallow well pump?
    By dave115 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-01-2010, 11:56 AM
  3. Pump on Sears shallow well pump runs too long
    By slackattack in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-27-2008, 06:12 AM
  4. shallow jet pump/bladder replacement
    By T_Hartigan in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-08-2007, 07:00 AM
  5. shallow well pump need help ????
    By djarp in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-20-2006, 02:40 PM
