Results 1 to 6 of 6
Thread: Shower drain gasket is too large for 2" drain pipe, what to do?
    DIY Junior Member Bratan's Avatar
    Feb 2013
    New York
    Question Shower drain gasket is too large for 2" drain pipe, what to do?
    Hello!
    I was wondering if someone could give me an advice about installing shower drain. This is my first time doing it. I'm basically replacing shower pan/tub and drain assembly. My drain pipe is 2" metal (copper?) and I bought a no caulk brass drain (made by Oatey) form Lowes. I was surprised to find out that it's a lot bigger (by about 1/2") than my pipe. Rubber gasket simply slides over the pipe, not even touching the walls I've read instructions and watched videos on how to do it, and it suppose to be pretty snug on the pipe. Am I doing something wrong, or drain is simply wrong size (it does say for 2" pipes on the label)? Or is it meant for PVC pipes that have thicker walls?
    I appreciate any suggestions
    Yes, your drain is meant for schedule 40 pipe, meaning ABS, PVC, etc. There is probably a gasket available for the copper pipe,
    I totally agree and you are correct.
    Feb 2013
    New York
    Thank you! Crazy... oh well, I hope I can find right one
    Quote Originally Posted by Bratan View Post
    You need an Oatey 101 series Model number 42050. Verify with oatey tech support that it caulks to the brass drain with a rubber grommet/bushing and caulk ring.
    Feb 2013
    New York
    Quote Originally Posted by Hackneyplumbing View Post
    Thanks! I wasn't able to find that specific part anywhere, but found a gasket (model 42158) that should work for copper pipe and compatible with my drain (42150). Only one store sells it tho, and shipping is 4x price of the gasket, but oh well If anyone interested I'll report if it fits once I receive it.
  1. Installing Kohler Shower Drain Gasket
    By sproksch in forum Shower & bathtub Forum & Blog
    Last Post: 06-04-2011, 02:17 PM
  2. Replies: 1
    Last Post: 09-27-2010, 05:55 AM
  3. how to connect plastic shower drain to 2" copper drain line?
    By showerpain in forum Shower & bathtub Forum & Blog
    Last Post: 01-31-2007, 08:36 AM
  4. Is 1 1/2" drain pipe ok for shower drain? and 2nd floor P-trap question...
    By paule123 in forum Shower & bathtub Forum & Blog
    Last Post: 06-12-2005, 10:15 AM
  5. shower drain won't fit undersized 2" pipe
    By mr ed in forum Shower & bathtub Forum & Blog
    Last Post: 10-13-2004, 05:45 AM
