Results 1 to 2 of 2
Thread: Doing a creative watering setup and have some questions on this.
    DIY Junior Member Joebif's Avatar
    Jan 2013
    Colorado
    Default Doing a creative watering setup and have some questions on this.
    I have a greenhouse with Fish and plants in it. This is called Aquaponics.
    I am growing in a room seedlings and have a setup hooked up to my cold water standard pressure line. I have a tank with a float valve and when the tank gets low the float valve tell the cold water to fill up the 10 gallon tank.
    I would like to add in to the setup some aquaponic nutrients. The seedlings get started okay with cold water but could use nutrients to get them to grow even faster.
    Here is what I am thinking but need help and want to make sure I do it right but also save on building it myself. I am thinking that this would be the same as a well pump set up but using a 110 volt submersible pump in my lettuce rafts where the nutrients are the cleanest.
    1. Have a water storage tank that gets filled with the use of that pump in the rafts.
    2. The storage tank would be plumbed into the cold water in my greenhouse with either a mixing valve or a T. I could either use a mixing valve that would allow me to mix in a percentage of nutrients to cold water or just use a ball valve on both lines so I could use either one full strength not sure yet on that.
    3. I would need a back-flow prevent-er so the fish tank water would not go into my cold water so when I wanted a drink it would prevent that. Or is there something better?
    4. I would need a pressure gauge and a small pressure switch to turn on the pump but not sure if this will work because the cold water I think would fool the pressure switch and the switch would never go down unless there is a way to do this and it would read the pressure in the nutrient side only.
    Any ideas? Does it look like I am on the right track?
    In the Trades Jerome2877's Avatar
    Aug 2009
    BC
    Definatley need a backflow device or you could use an air gap by piping above your storage tank so the water supply is not directly connected.
  1. New well setup questions
    By cursethebanksters in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-24-2012, 04:00 PM
  2. Do I need a well-point for preexisting cased well? Setup questions, PVC alternatives?
    Last Post: 07-26-2012, 11:28 AM
  3. Well pump setup questions
    By Goonberry in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-16-2012, 09:21 PM
  4. Well Drilling and Setup Questions
    By milkman1 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-09-2009, 08:39 PM
  5. Creative Plumbing
    By Verdeboy in forum Plumbing Forum Discussion & Blog
    Last Post: 07-12-2007, 09:57 PM
