Results 1 to 1 of 1
Thread: Shower leaking behind faucet/wall
Hybrid View
    DIY Junior Member Anton Derson's Avatar
    Feb 2013
    Colorado
    Default Shower leaking behind faucet/wall
    Ive been trying to manage this leak with my lack of plumbing knowledge. And I dont think its from the diverter. I've taken off the valve covers and removed/examined and tightened the escutcheon. I've taken pictures of my shower, and the leaky spots. I've tinkered with the water pressure with no luck.
    The leak only occurs when the shower is actuated. Both hot and cold sides leak.
    My shower setup: valve stems w/ diverter in spout to push water up shower arm:
    (yes, the cold valve screw is not in place, picture taken during my trouble-shooting)
    The leak, behind the faucet assembly
    Notice the stripped paint and water stain running down wall
    Unnecessary:
    I'm thinking I need to replace the nuts behind the faucet, my faucet assembly is fine?
    To do this I should?:
    Turn off water
    Remove escutcheon and valve stems
    Loosen the house piping from the faucet piping
    Loosen/remove/replace nut , probably just tighten?
    Reassemble
    Correct?
    The nuts w/ blue hold the faucet assembly to the wall, it appears.
    Edit: upon further tinkering i noticed the washered nuts w/ blue mineral deposits are loose, started to tighten but space restrictions are hindering me. To get behind the wall I must lean over very far over access wall, so far that my feet are hanging and I'm upside-down. My shoulders barley fit into the access hole, maybe just bigger than a 2'x3' hole.
  1. Leaking in-wall lav faucet valve
    By oddjob in forum Plumbing Forum Discussion & Blog
    Last Post: 02-22-2010, 11:24 PM
  2. Wall Outdoor Faucet Leaking
    By 100South in forum Plumbing Forum Discussion & Blog
    Last Post: 05-27-2008, 11:26 AM
  3. bathtub faucet leaking in the wall
    By trytoplumb in forum Shower & bathtub Forum & Blog
    Last Post: 11-11-2006, 10:37 PM
  4. Shower leaking in wall
    By rocks911 in forum Shower & bathtub Forum & Blog
    Last Post: 09-07-2006, 10:40 AM
  5. leaking between tub faucet and wall when shower is on - HELP pls!
    By christine in forum Shower & bathtub Forum & Blog
    Last Post: 03-29-2005, 08:49 PM
