Results 1 to 3 of 3
Thread: Help with Culligan Gold Series Metered 9" WS float
    DIY Junior Member coriolis2k's Avatar
    Feb 2013
    Wisconsin
    Default Help with Culligan Gold Series Metered 9" WS float
    Name:  2-14-2013 6-45-56 PM.jpg
Size:  26.2 KBSo, first off this site has been crazy useful in determining my original problem and providing the info required to fix.
    Now I am stuck. The problem was origenally that my system was not using salt nor providing soft water. I pulled the unit apart and found that it was not pulling from the brine tank......no suction. After searching some threads here I found the answer to be purchasing a main seal replacement kit and that took care of the suction issue. Now it does not seem to push water back into the brine tank after pulling it out for the wash. I did take the float assembly appart and think I may have put it back together incorrectly.
    I "borrowed" these images from another website, as they show exactly what I have. My question is this:
    Does the picture represent the correct placement of the plastic ball? It shows the 3 legged "table" with the legs going down into the black plastic housing, then the little plastic ball, then the upside down "golf tee" resting on top of the plastic ball. Is that correct?
    Dec 2009
    Alaska
    I just took one apart that was part of a trade in.
    The ball goes in first , then the little table with the legs up and then the plunger.
    At least that was the way the one that I took apart was.
    Feb 2013
    Wisconsin
    Thank you Sir!
  1. Culligan Gold/Silver Regenerating daily
    By Dankon in forum Water Softener Forum, problems, installation and reviews
    Last Post: 04-20-2012, 04:53 PM
  2. Culligan Mark 89 float adjustment
    By ScottyB in forum Water Softener Forum, problems, installation and reviews
    Last Post: 10-28-2011, 06:16 PM
  3. Culligan Gold series softener has constant overflow
    By kerby in forum Water Softener Forum, problems, installation and reviews
    Last Post: 10-14-2010, 06:46 PM
  4. Replacing boiler with a gold series, good deal??
    By Gnfanatic in forum Boiler Forum
    Last Post: 07-22-2010, 03:46 AM
  5. Kinetico Sulfur Guard vs. Culligan Iron-Cleer/Gold Softner
    By marcopolo in forum Water Softener Forum, problems, installation and reviews
    Last Post: 08-21-2009, 01:09 PM
