Results 1 to 3 of 3
Thread: Moving Shower Vent
    DIY Junior Member Mikeiii's Avatar
    Jan 2009
    California
    Default Moving Shower Vent
    I want to remove the wall in green which currently has the shower vent running up thru it.
    The distance from trap to vent is about 12" and trap to 90 Degree in existing sewer line is 4 feet.
    Will this configuration meet code?
    Jan 2008
    You can do that, but you will have to install an accessible cleanout due to the amount of bend you have added to the line.
    Jan 2009
    California
    Thanks cather_chick!
    I was concerned about all the bends so it makes sense to include a cleanout.
    The vertical pink vent pipe is accessible through a closet behind the bath.
    Can a cleanout be in the vent?
    Is one enough?
  1. Kitchen Sink... No Vent? Plus Moving Plumbing
    By monkeystomach in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-26-2011, 01:08 PM
  2. Moving a toilet (with a flat vent)
    By winklebe in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-20-2009, 08:47 PM
  3. Moving vent Stack
    By nelsonba in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-13-2007, 03:49 PM
  4. Moving a cast iron main vent..help?
    By drector30 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-07-2006, 06:46 PM
  5. moving vent stack in cement foundation
    By JCT in forum Remodel Forum & Blog
    Last Post: 12-31-2005, 07:19 AM
