Results 1 to 4 of 4
Thread: Hey!!!! a new shower...
    DIY Member royerm's Avatar
    Jul 2010
    Quebec, Canada
    Thumbs up Hey!!!! a new shower...
    After reading and reading and reading.
    I decided to replace my old 38x38 neo-angular by a 36x60.
    I have included a before and after image, so much help on the forum..
    ThxName:  IMG_3127.jpg
Size:  54.9 KBName:  IMG_3194.jpg
    Feb 2011
    NW Ontario, Canada
    I used to have a boss that liked the saying "it looks good from far, far from good". It does look good as a finished product but I have concerns. The wet wall doesn't look stiff enough. Is that niche cut into an exterior wall with no insulation behind it?
    Jul 2010
    Quebec, Canada
    The wet wall was added a few studs, Backerboard was used and the niche on the exterior wall
    is insulated,,,just not showing on the picture..
    Jul 2009
    North Vancouver, BC
    I might suggest you install a few weep holes on the bottom side of your shower unit. I have found that there is a little build up of moisture inside the box and a few weep holes drilled in the right spot can help keep this from making things nasty back there.
    JW
