Results 1 to 6 of 6
Thread: newbie tub (tile) install question
    DIY Junior Member darren b's Avatar
    Feb 2013
    Ontario
    Default newbie tub (tile) install question
    Hey guys i installed my first acrylic tub last week. the tub is installed, I ran my backer board 1/4" above the 1" flange on the tub.(as per mirolin instructions ) I also coated the backer board with mapie auqa defence. my problem now is what is the best way to seal the 1/4" gap I have between the backer board and the tub flange? I will be installing 6x6 tile for the tub surround. Looking at it now, i maybe should of ran the backer board rate over the tub flange, but like i said I am a newbie reading the tub instuction sheet. thanks for the help
    Jan 2008
    The installed tiles are all that is needed to cover the gap. Leave 1/4" between the bottom row of tile and the tub deck for caulk.
    As long as less than half the tile is cantilevered over the tiling flange, it should be okay structurally since you're not walking on the wall. You don't need as much as a 1/4", but you do want a gap that can be easily caulked. Consider foam backer rod in there - it produces a better caulk joint.
    Feb 2013
    Ontario
    thanks guys, i was concerned about the gap, but if i caulk it good it should hold up, any makes of caulking i should be looking for? i live in Canada thanks
    DIY Member SH140's Avatar
    Jan 2013
    Vallejo, Ca.
    Quote Originally Posted by darren b View Post
    This is good to know because I thought I read that the backerboard came down "over" the tiling edge of tub to a 1/4" above the tub itself. This sounds much better and easier when the tile goes on. Thanks
    You want at least your vapor barrier from behind the cbu to come down over the tiling flange. Some tubs have a fairly tall tiling flange, and some are quite short...it's better to have the cbu come down over the flange. To do this takes some work; either, notch the studs so the flange is flush, use some spacers on the studs to bring it out, or depending on the cbu, sometimes, you can put a rabbit on the back without compromising it (not the easiest thing to do without it all breaking up). You do not want the cbu bent over the flange.
  1. Vespin II install on tile
    By danix in forum Toilet Forum discussions
    Last Post: 04-24-2011, 01:30 AM
  2. Replies: 10
    Last Post: 04-15-2009, 08:12 PM
  3. Newbie Question: Toilet Install
    By DerekW in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-21-2008, 04:04 PM
  4. tile shower install
    By gfe76 in forum Shower & bathtub Forum & Blog
    Last Post: 11-06-2007, 06:44 PM
  5. Newbie, first bathroom install would like some advice
    By myrightnut in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-24-2006, 08:03 AM
