Results 1 to 6 of 6
Thread: Need quick advice on 3 floor bathroom layout
    DIY Junior Member Jozart's Avatar
    Feb 2013
    South Carolina
    Default Need quick advice on 3 floor bathroom layout
    I have attached a sketch of what I intend to do to add a bath to a thrid floor attic. A 1/2 bath was roughed in but I wanted to change the horizontal drain to accomodate a shower. I can only add a seperate vent to the shower upstream of the shower p-trap is this OK? I may not even need one given that its also vented (wet) via a kitchenette sink I will also add. This is vented through a seprate stack.
    See sketch for details. NOTE: RED lines indicate vertical runs
    Thanks in advance.
    Joe
    Feb 2013
    South Carolina
    Please note that the 1 1/2" vent upstream of the shower runs parallel with the 2" drain before turning up (30" run) to go vertical through the roof on a seperate vent
    A kitchen can't wet vent any bathroom fixtures.
    Wet venting is only for a bathroom group on the same floor.
    If you have a sink above, the waste for that will have to come in lower or downstream of the shower.
    Feb 2013
    South Carolina
    Thats what I thought you'd say. I can tie into the drain down stream of the shower with a little work. How abour the vent thats near the shower wye? is that OK?
    Jan 2008
    The vent for the shower should come off the trap arm, not the stack.
    IF you leave the stack the way it is, and reroute the sink connection below the shower, with its own vent, then you do NOT need that separate vent.
  1. DWV Layout Basement Bathroom - layout review
    By great white in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-13-2012, 05:28 PM
  2. Please look i need expert advice quick!!!
    By vtxdude in forum Water Heater Forum, Tanks
    Last Post: 12-03-2009, 10:31 AM
  3. Bathroom Re-model Layout Advice #2a
    By ralft in forum Remodel Forum & Blog
    Last Post: 08-11-2006, 03:48 PM
  4. Bathroom Re-model Layout Advice
    By cjt in forum Remodel Forum & Blog
    Last Post: 08-02-2006, 06:26 AM
  5. Bathroom Re-model Layout Advice #2
    Last Post: 07-22-2006, 05:26 AM
