Results 1 to 6 of 6
Thread: Low clearance recessed lights...
    DIY Member locus123's Avatar
    Sep 2009
    Ontario
    Default Low clearance recessed lights...
    I have low hanging ductwork that is framed in with 1" of clearance (they used metal RC strapping). It's against a wall in an area that needs some lighting. Does such a solution exist where recessed lights are less than 1.5" (0.5" for drywall) deep?
    Originally I planned on using LED lights, but all that is nearby is the light switch box (drywall up the walls, ceiling, etc). I have nowhere to put a transformer, unless I'm allowed to slip it up with the lights, and that assumes it's 1" thick.
    Thoughts?
    Jun 2007
    North Carolina
    Quote Originally Posted by locus123 View Post
    Thoughts?
    Table lamp?
    bulbs and reflectors are more that 1" deep. You are trying to do the impossible.
    Sep 2009
    Ontario
    Ya, that's what I thought. I was hoping there was a sneaky way to make LED work up there. I know there are some less than 1" deep, but I'm still in trouble with the transformer cause I have nowhere to hide it.
    OK, no worries, thanks.
    IF you found an LED that fit in the 1 1/2" space, I hope you would not need much light there, or had room for a LOT of the lights.
    DIY Junior Member ashleypaxtonn's Avatar
    Feb 2013
    Sun Life Plaza, West Tower, 2600, 144 - 4th Avenue, S.W.
    I think LED's are the solution. I fixed one in my room and the illumination was perfect. Though it takes a lot of trial and error to find the perfect setting.
    World will surely go round. Learning Center
  1. Code clearance between ABS and recessed lighting?
    By Buttonsrtoys in forum Plumbing Forum Discussion & Blog
    Last Post: 01-12-2013, 06:47 AM
  2. insulating recessed lights
    By possum in forum Remodel Forum & Blog
    Last Post: 12-22-2008, 10:31 PM
  3. Recessed Lights and Insulation
    By sctclimbs in forum Remodel Forum & Blog
    Last Post: 11-17-2008, 11:51 AM
  4. Recessed lights burning out
    By tlarson in forum Electrical Forum discussion & Blog
    Last Post: 10-29-2008, 03:35 PM
  5. 3" recessed lights
    By Georgeoh in forum Remodel Forum & Blog
    Last Post: 01-09-2007, 01:49 PM
