Results 16 to 30 of 44
Thread: How to increase water pressure/flow in showerheads
  1. #16
    DIY Member CindyJ's Avatar
    Nov 2012
    Pennsylvania
    1/2" cpvc is too small for any but very short runs.
    How long or short is a "short run?"
  2. #17
    Nov 2012
    Pennsylvania
    We had a deadly combination of low pH and copper piping, and after 35+ years, pinhole leaks developed. We had never had our water treated for low pH because we didn't know it was problematic. The first leak caused over $3,000 in damage. Since we had no way of knowing how extensive the leaking problem was, or where other leaks might (or already had) develop(ed), we decided to replace all of the piping.
    We did consider PEX, but (and this will probably sound like a copout) the repipe project was something my husband was handling, and for reasons I can't recall at the moment, the decision was made to go with CPVC.
  3. #18
    Nov 2012
    Pennsylvania
    Quote Originally Posted by valveman View Post
    With a pressure switch turning the pump on at 40 and off at 60, shower pressure will never be very good. Installing a CSV could make the system maintain 55 PSI constant. That would seem like so much stronger pressure in the shower, that you almost no longer need soap (lol). Also if the pump is cycling on and off while the heat pump is running, as I am sure it is, you need a CSV to keep from burning up your pump/motor on a regular basis.
    Given what I now know is a reduced flow owing to the replacement of copper piping with CPVC, would a CSV be safe to use with 1/2" CPVC?
  4. #19
    Nov 2012
    Pennsylvania
    I suspect the basic problem relates to your pipe replacement. Based on inside diameter, you need to upsize CPVC by one nominal size to equate to copper. In other words, replace 1/2" copper with 3/4 CPVC, replace 3/4 with 1", etc. 1/2" cpvc is too small for any but very short runs.
    ...and another question: We're about to replace all of the old toilets in the house with Toto Ultramax II. Will the reduction in water pressure affect the flushing capability of the new toilets?
  5. #20
    Jan 2008
    It will not matter, because all of the water used when flushing comes from the toilet's tank.
  6. #21
    Feb 2011
    NW Ontario, Canada
    Most toilets do not rely on water pressure to flush, only gravity.
    Have you done the flow measurements into a bucket as I suggested? It is premature to talk about pipe size if the shower valve is the limiting factor. Pipe size affects pressure only relative to flow. Right now, I suspect the shower head is the limiting factor.
    Have you taken elevation into consideration? How much elevation difference is there between where the pump pressure switch is and where the shower head is? You can count on .43 PSI loss for every foot of elevation.
  7. #22
    Plumber jimbo's Avatar
    Thank you for the feedback.... you do have the relatively uncommon, but the one situation ( low ph) where copper has problems. Doing a repipe with the relatively unflexible CPVC must have been a chore.
  8. #23
    FWIW, both CPVC and PEX have a lower flow capacity verses copper based on the same nominal size. This is because the outside of the pipe is what is controlled, not the inside, so because the plastic pipes need more strength, their walls are thicker, thus, the ID is smaller.
    What would have worked better was to have 3/4" pipe running to the shower, then converting to 1/2" (which is probably the valve's inlet size, although some are 3/4" or even larger). Most things can function fine on 1/2", but high flow or multiple fixtures off one line need a larger supply coming into the area, then branching off with smaller pipes, where appropriate. If they ran 1/2" to the bathroom group, you'll find a real issue if someone flushes the toilet or tries to run the vanity sink while you're in the shower!
  9. #24
    Quote Originally Posted by CindyJ View Post
    We have our own well and the pressure cycles between 40 and 60 PSI.
    I would rather see a static pressure of around 75psi and no higher than 80psi.
  10. #25
    Feb 2011
    NW Ontario, Canada
    Quote Originally Posted by Hackneyplumbing View Post
    With the pressure switch adjusted to 60/80 and a CSV properly dialed in, the OP could see just that.
  11. #26
    Jan 2008
    40-60 does a fine job with the right shower head. I would speculate that the majority of homes in the U.S. have less than 60 psi.
  12. #27
    Let a guy get use to 70-80 psi and cut it back to 40-60 and you'll have complaint after complaint.
  13. #28
    Nov 2012
    Pennsylvania
    The specs for that model say it has a 5.0 GPM flow rate. Most modern shower heads are 2.5 GPM. You could capture the flow into a bucket and calculate it, then remove the head and repeat the test. That will give you some indication of how much you might gain by defeating any flow restriction in the head. It is unlikely that you can change the flow characteristics in the valve.
    Okay -- I did the "bucket test." I should mention that my husband has removed the flow restrictors on both the stationary and hand-held showerheads. I ran two tests. The first one ran at 2.3 GPM, the second one was 2.5 GPM. I'm guessing that the variation was due to the cycling of the pump pressure.
    So now my question is, is this more a matter of increasing the water pressure, or changing the CPVC from 1/2" to 3/4"? Or should we do both?
  14. #29
    Nov 2012
    Pennsylvania
    I went down to the basement and the good news is that there is 3/4" pipe running from the filter to various places in the house. Or maybe it's just news, not necessarily good news because I don't know the size of the original copper pipe that was replaced with CPVC. What is still unknown is where, exactly, the 1/2" is joined to the 3/4". I do know that both bathroom showers are served with 1/2" pipe from the same split source. That, alone, is probably cause for concern.
    I'm expecting my plumber here today and I'll certainly have a conversation with him about this.
  15. #30
    Nov 2012
    Pennsylvania
    When you say "static pressure," does that mean a consistent water pressure as opposed to water pressure that fluctuates when the pump turns on and off?
  1. Increase water flow/pressure for a well system
    By Rattler 24 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-21-2012, 04:54 PM
  2. How to increase low flow toilets water flow
    By Lisa J. in forum Toilet Forum discussions
    Last Post: 07-26-2011, 01:31 PM
  3. Low Flow Rain Showerheads
    By brian3b in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-25-2009, 06:15 AM
  4. attic tank to increase pressure/flow
    By Erico63 in forum Solar and Geothermal Water Heating Forum
    Last Post: 03-20-2008, 07:13 AM
  5. attic tank to increase pressure/flow
    By Erico63 in forum Pumps and Tanks Well Forum & Blog
