Results 1 to 4 of 4
Thread: Vaper lock in a gravity fed water system.
    DIY Junior Member KERRBEAR's Avatar
    Feb 2013
    CUTLER,OHIO
    Default Vaper lock in a gravity fed water system.
    I have a gravity fed wter system coming from a spring. I have water coming into the main line, but not coming into the house. I'm sure it has to be a vaper lock but not sure how to remedy the problem.
    Feb 2011
    NW Ontario, Canada
    Apply suction.
    IF there is any "positive pressure" from the spring, it will NOT vapor lock. The water will push the air out ahead of it.
    Feb 2011
    NW Ontario, Canada
    That would depend on how the line is run. If any of the line rises high enough, it may rely on siphoning to overcome the high spot.
  1. Gravity fed spring water system
    By LaneH in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-01-2012, 10:13 PM
  2. Gravity septic system
    By Suthnr in forum Plumbing Forum Discussion & Blog
    Last Post: 03-22-2012, 12:31 PM
  3. Gravity fed water system help
    By extendedpath in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-20-2011, 09:23 AM
  4. Converting a pumped recirculation hot water system to GRAVITY
    By luc in forum Plumbing Forum Discussion & Blog
    Last Post: 04-24-2007, 07:33 AM
  5. How do I plumb a primitive gravity-flow water system?
    By Terry in forum Plumbing Forum Discussion & Blog
    Last Post: 04-18-2005, 09:03 AM
