Results 1 to 2 of 2
Thread: Upgrade For 90 Degree Urinal Flush Valve?
Hybrid View
    DIY Member PM5K's Avatar
    Oct 2006
    San Antonio, TX
    Default Upgrade For 90 Degree Urinal Flush Valve?
    I'm assuming the only way I can is by having the supply line moved over to the side, is that correct or do you pros know of any other options?
    IF I knew what you were talking about, and what you wanted to do, I might be able to give an answer.
  1. Mansfield 208 flush valve seal...replace or upgrade
    By GKWilly in forum Toilet Forum discussions
    Last Post: 01-28-2013, 03:33 PM
  2. Piston valve vs Diaphragm valve for urinal
    By gtmtnbiker in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-30-2012, 10:39 AM
  3. Relocating Toilet - 45 degree or 90 degree fitting?
    By ED1 in forum Toilet Forum discussions
    Last Post: 09-13-2009, 09:35 AM
  4. Valve with degree marks.. What is it?
    By 502_Jimmy in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-28-2008, 10:12 AM
  5. Low flow urinal from American Standard and dual flush valve from Sloan.
    By Ivona in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-18-2007, 07:26 AM
