Results 1 to 2 of 2
Thread: Upgrade For 90 Degree Urinal Flush Valve?
    DIY Member PM5K's Avatar
    Oct 2006
    San Antonio, TX
    Default Upgrade For 90 Degree Urinal Flush Valve?
    I'm assuming the only way I can is by having the supply line moved over to the side, is that correct or do you pros know of any other options?
    IF I knew what you were talking about, and what you wanted to do, I might be able to give an answer.
  1. Mansfield 208 flush valve seal...replace or upgrade
    By GKWilly in forum Toilet Forum discussions
    Last Post: 01-28-2013, 03:33 PM
  2. Piston valve vs Diaphragm valve for urinal
    By gtmtnbiker in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-30-2012, 10:39 AM
  3. Relocating Toilet - 45 degree or 90 degree fitting?
    By ED1 in forum Toilet Forum discussions
    Last Post: 09-13-2009, 09:35 AM
  4. Valve with degree marks.. What is it?
    By 502_Jimmy in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-28-2008, 10:12 AM
  5. Low flow urinal from American Standard and dual flush valve from Sloan.
    By Ivona in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-18-2007, 07:26 AM
