Results 1 to 7 of 7
Thread: Problem with water suction
Hybrid View
    DIY Junior Member kevin102's Avatar
    Feb 2013
    Ireland
    Default Problem with water suction
    Hi all,
    Anyone see the problem here! I have tried everything but nothing seems to work. Maybe the pump is not strong enough?
    Thanks,
    Kevin
    Jan 2008
    Maybe a silly question, but did you prime it?
    Feb 2013
    Ireland
    Yes Primed it several times, even went as far to add a ballcock valve at center of hose where a garden hose could be attached and water pushed through the pipe until primer at pump was overflowing. when we switched pump on it sucked for a bit but then nothing!
    Jan 2008
    If there are any joints on the suction side I would start there. Any air/suction leak will do it.
    Feb 2011
    NW Ontario, Canada
    Use a submersible and you will never have priming issues or a pump not strong enough.
    Feb 2013
    Ireland
    Yes LLigetfa, I soon realized I made a huge blunder in my purchase of this type of pump, submersible is they way to go
    Feb 2013
    Ireland
    Thanks cacher_chick, I think I may have spotted a suction leak at the pump itself! cheap china plastic intake nozzle grrrr I'll call into the local fittings store and buy a brass nozzle instead.
  1. Pressure verses Suction
    By scottj in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-04-2008, 05:39 PM
  2. what rating suction line should I use?
    By Byoung5187 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-03-2006, 05:17 PM
  3. suction line air leak
    Last Post: 10-02-2006, 05:35 PM
  4. Suction Side Leak
    By K1LE in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-19-2006, 09:29 AM
  5. Water Hammer - Shallow Well Suction Line
    By Garyt in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-10-2005, 12:35 PM
