Results 1 to 13 of 13
Thread: Is this shower drain to code?
    DIY Junior Member Mikeiii's Avatar
    Jan 2009
    California
    Default Is this shower drain to code?
    Can a shower drain be added to this existing washing machine drain?
    The pink pipes in the diagram would be new?
    Mike
    No, when the WM was running, it would siphon the proposed shower drain dry. EACH trap needs a vent. Depending on how big that pipe is, you might be able to do it IF you added a vent, but a WM drain line can be problematic. You don't want sudsy water getting pumped into your shower!
    Last edited by jadnashua; 02-05-2013 at 08:18 PM. Reason: changed drain to vent....
    Jan 2009
    California
    Thanks for the answer.
    I know very little about drains but I'm trying to remove a shower wall that contains a vent. (the green wall in the diagram)
    Would there be too many bends in the line to bring the shower drain to the vent in wall A and from there back to the current drain below the green wall?
    Jan 2009
    California
    Would this setup work?
    Jan 2008
    If you look at your first drawing you will note that the vents are vertical. They have to be that way to ensure that no waste ever backs into the vent and stays there.
    Jan 2009
    California
    Thanks.
    I'm starting to understand.
    I do have a sink drain with a vent that is vertical but it would be a 6ft run from the shower trap.
    Is that too far?
    The vent must come off of the trap arm before the waste turns down, and must be within 5' with a 2" pipe. It must go vertical before it can go horizontal.
    Jan 2009
    California
    Thanks I think it is going to work.
    Plumber Sean Beck's Avatar
    Jun 2013
    Toronto, Ontario, Canada
    Quote Originally Posted by Mikeiii View Post
    Mike
    You could say that the drain upstream of the proposed pink drain could be a wet vent, and providing that that drain is 1.5", then it can take up to 2FU (fixture units) which would cover the washing machine. You just have to make sure the distance from the trap of the shower to the proposed wet vent would be more than 2 x the diameter of the drain pipe (so probably 3 inches).
    Jan 2008
    Most codes only allow wet venting bath groups, so venting past the laundry would not be permitted.
    Right.
    No inspector would allow a washer in any wet vent situation. That washer would suck the trap so fast it wouldn't be funny.
    Nov 2010
    Maine
    Not only that but the washing machine rain has to drain into a 3" or larger horizontal or vertical branch.
    DIY Junior Member frodo's Avatar
    Jun 2013
    Mississippi
    can you do this ..
    the tree of liberty must be refreshed from time to time with the blood of patriots and tyrants
    herzlichen gluckwunsch zum dd ich bin uberrascht wen nicht alies da findet
  1. Code requirement for custom shower drain?
    By Stealthfox in forum Shower & bathtub Forum & Blog
    Last Post: 03-17-2013, 12:33 PM
  2. Shower Drain Size and Code
    By centurion in forum Shower & bathtub Forum & Blog
    Last Post: 02-19-2012, 06:27 AM
  3. shower drain & p trap code question
    By nc8861 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-20-2008, 05:19 PM
  4. Code for Steam Shower Line/Drain
    By colbymom in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-08-2008, 04:16 AM
  5. drain code HELP!
    By Racerxjling in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-25-2004, 06:20 AM
