Most boilers can safely operate at that or possibly even higher temperatures. That is one reason for maintaining them under pressure just like your car's radiator...raising the pressure, raises the boiling point. The taller the building, the higher the pressure that may be 'normal'.
It's possible that the boiler has something called an outdoor reset, which monitors the outside temperature, and adjusts the boiler's setpoint so it can still produce heat economically.
