Results 1 to 3 of 3
Thread: pipe length for basement bathroom fan
    DIY Senior Member diyfun's Avatar
    May 2011
    MA
    Default pipe length for basement bathroom fan
    I have an unused dryer outlet opening. Now I need a basement bathroom fan. It will be nice to use that existing opening. But it is about 25ft away. Piping from bathroom to that opening is easy. Do you think it is good a idea to have a 25ft long passage for the dump air flowing out the basement? insulate the pipe for condensation concern?
    thanks
    That probably exceeds the manufacturers limit for duct length, but the only way to know for sure is to look at various spec sheets for units you might want. In addition to the total length, you have to add to that for every elbow (change of direction - they slow the flow down, and look like a longer duct). It also makes a huge difference whether the duct is smooth or corrugated...corrugated will make it look MUCH longer.
    Jul 2009
    North Vancouver, BC
    Corrugated pipe should be outlawed. We never use it. Smooth pipe all the way.
    We have installed many Panasonic fans with this longer run and have never had a problem. Removing moist air is more important than living with it because the run is too long.
    Try and tape of and insulate the new fan. Keep the seam on the pipe on the top. Always feed from the exterior wall to the fan so that the pipe closest to the outside wall gets the new crimped duct pipe inserted into it. This makes sure you drain properly and do not built up hair balls.
    JW
  1. Pipe length
    By Viking in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-12-2011, 04:46 PM
  2. Basement Bathroom pipe dry fit review before cutting concrete
    By abdixonga in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-06-2010, 02:10 PM
  3. Basement Bathroom Stink Pipe
    By Helen Wohlgemuth in forum Toilet Forum discussions
    Last Post: 05-21-2006, 11:52 AM
  4. Maximum length of duct for bathroom fan
    By Douche in forum Shower & bathtub Forum & Blog
    Last Post: 04-13-2006, 07:12 AM
  5. Vent pipe length
    By thezster in forum Remodel Forum & Blog
    Last Post: 08-07-2005, 08:46 PM
