That is a very good question because I also don't know how it's connected b/c they are on opposite sides of the room, but I'll have a look at the shower side when I get home. Fortunately, I have easy access to find that out. Quick question however - you mentioned that you still don't know how the tub/shower is connected....why does that matter exactly? The only change that there will be, will be an extended drain line from the toilet so instead of 1ft. to the toilet, it will need to be 3'-4' in another direction.
I think I'll get cracking (no pun intended) on breaking up the bit of concrete which houses the receiving hub and this should give me/you guys a better indication of where the lines sit. Thanks again!
We don't know where the building drain is. Going only by your pictures, the tub/shower branch drain could be connected near the base of the stack under the floor. If so it will have to be considered when installing the new toilet branch.
