Originally Posted by
Dana
Buying closed cell foam in 12 bd-ft FrothPak kits is about 3x the cost of buying the same volume of foam in rigid XPS form, but you can even-up uneven surfaces with it.
The material stackup of the existing walls and any insulation matter in terms of what you do with the rest, the biggest problem area being pre-existing poly vapor barriers. In a new stackup you may need to get rid of any prior vapor retarders, or you'll need to skip interior side vapor retarders &/or balance the R-values of the insulation outside the vapor barrier & interior side vapor barrier to keep the average temp at the vapor barrier above the dew point of the air.
For insulating concrete foundations it's usually better to use some amount of rigid-foam against the concrete and trap it to the wall with a studwall, then insulate the studwall with unfaced stone wool or fiberglass. This can work for your wood sections as well, but to get the R-balance right we need to know the existing constuction stackup, and your location (for weather data/climate information- Ontario is a big place, covering climates ranging from near-arctic to fairly temperate near the southern Great Lakes shores, and the "right" stackup will vary.)
